Spacers
Old Apr 14, 2008 | 06:45 AM
lexus2332's Avatar
lexus2332
Default Spacers
I put some 20x8.5 inch wheels on my gs300 with 35 offset. I want to add spacers to the rear. What would be a good size to go with to make it flush?
Old Apr 14, 2008 | 07:46 AM
SorrGwa's Avatar
SorrGwa
if u add spacers, u need longer studs to be pressed in. an alternative is wheel adapters such as "project kics"
as for how thick, a 20x10 +43 sits just good enough without rubbing and without fender rolling.
just did some quick calculations, you should be able to run a 25mm spacer. that will make it sit close to flush. hope someone can follow up with my calculations to make sure they are right. =)
Old Apr 14, 2008 | 05:46 PM
MJImport's Avatar
MJImport
I was told by an employee at tirerack that as long as you can get 7 turns on the stud you don't necessarily have to replace them.
Old Apr 14, 2008 | 07:24 PM
GS FONZy's Avatar
GS FONZy
You need to let us know what tire you have and if you would like to mod your fenders or just push the wheels out to match the front?
I heard five. Etherway, most spacers come with longer studs. Only the cheap pep boys, etc... are the ones that don't come with anything.
Old Apr 14, 2008 | 07:34 PM
SorrGwa's Avatar
SorrGwa
ive never seen h&r spacers come with longer studs, though i could be wrong. you would still need them pressed in. i wouldnt trust any other brands cept for project kics for quality wise.
the h&r spacers ive seen have mainly been for euro's, which come with longer bolts.
from my experience, anything more than a 5mm will mean about that 7 turn rule.
Old Apr 14, 2008 | 07:41 PM
GS FONZy's Avatar
GS FONZy
Search, then come back and post a new comment because this one is BS.
Many members have H&R and others brands that come with longer studs. Speaking from someone that currently has some, H&R and ICHIBA spacers. They work just fine and they are a good quality product.
Old Apr 15, 2008 | 11:16 AM
SorrGwa's Avatar
SorrGwa
re read, i said the hr spacers ive mainly delt with were for euros. euros use stud bolts and not lug nuts, thus its much easier for them to run spacers as its just a matter of using a longer stud bolt. i am not aware that H&R spacers for japanese/domestic vehicles come with longer studs which would need to be pressed in.
i did not denounce H&R spacer quality, however i am more concerned with running a spacer and not long enough stud for the lug nut to thread onto.
Old Apr 15, 2008 | 11:24 AM
PushinLEX's Avatar
PushinLEX
Uhhhhhhhhhhhhhhh, I'm running H&R DRM 25mm spacers for my rear wheels. And they come with extended stud bolts AND lug nuts. I think I'ma do a write up on this topic soon. Oh yea, I'm on 19x8.5 with a mild offset and it sits close to the fender but not quite flush.
Old Apr 15, 2008 | 03:18 PM
GS FONZy's Avatar
GS FONZy
You go back and forth on what you say, so I don't know if you mean what you say or just type away.
BTW, studs being pressed in, which you repeat in every post, it's very simple to do.
Old Apr 15, 2008 | 04:20 PM
SorrGwa's Avatar
SorrGwa
ahh, cools. good to know now. i decided not to go with H&R spacers because of the pressed studs. I still use my stock 16s w/ winter tires and wanted the ability to not use the spacer if i choose to. with longer studs, im not sure if the stock lug nuts will still fit.
I did take some quick pics when installed my spacers, but never did much of a write up. very curious to see the differences between different styles of spacers.
Old Apr 15, 2008 | 04:21 PM
SorrGwa's Avatar
SorrGwa
ok, you've made ur point ethugger...
Old Apr 15, 2008 | 05:50 PM
upstateGS4's Avatar
upstateGS4
ahh, cools. good to know now. i decided not to go with H&R spacers because of the pressed studs. I still use my stock 16s w/ winter tires and wanted the ability to not use the spacer if i choose to. .......
this is the h&r 25mm with the built in studs the guys were talking about, theres no work involved other then bolting them to the hub, and bolting the wheel to the spacer - effectively using two sets of lug nuts and no "pressing" of studs required. i also use these up front ( & 30mm in the back) when my stock wheels have to go on the car. this causes zero rubbing issues with tein cs v2 lowered all the way down
h&r also makes smaller spacers, but those ones do require you to replace the studs (included in kit), pictured below
you cant get the h&r with the built in studs for the gs in any other size besides 25mm, but project kics and a few other brands have them available in 15mm, 20mm and 30mm apps.
for the most part companies dont make anything less then a 15mm with the built in stud because it can cause fitment problems if the back of the wheel doesnt have cutouts to allow room for the part of the factory stud that would stick out past the spacer after its bolted up... know what i mean?
hope this answers some questions.
Old Apr 15, 2008 | 06:57 PM
lexus2332's Avatar
lexus2332
Thanks guys, really helped me out. Just ordered 25mm spacers, should be here soon.
Old Apr 15, 2008 | 09:12 PM
GS FONZy's Avatar
GS FONZy
Hope you are a DIY type person because you will need to mod the fenders to fit that big of a spacer. GL
Old Apr 15, 2008 | 09:49 PM
FinLIFE's Avatar
FinLIFE
Isnt the stock 17" wheel 7" wide with a 50 offset? I thought that running a 25mm spacer on a stock wheel makes it sit pretty flush. So a wheel 8.5" wide with a 35 offset will sit pretty flush? am I right?
