Headlight Adjustment Question...
Old Apr 4, 2008 | 01:03 PM
charmz's Avatar
charmz
Default Headlight Adjustment Question...
Well.....
Heres the deal.
I adjust the headlights in my garage with the car on and lights on until the "bubble" is in the zero section of the level (about 2 feet away from the wall). Then I pull out of the garage and onto a flat road, I check the level again and it seems the headlights are aimed WAY up high again.
Is this normal?
What am I doing wrong?
Where is the bubble supposed to be?
Old Apr 4, 2008 | 01:13 PM
Solo_D33A's Avatar
Solo_D33A
I think it's best imo to go onto a empty road at night and adjust the beam to where you like it...
Old Apr 4, 2008 | 01:38 PM
chrispy's Avatar
chrispy
Ignore the bubbles. The best way is trial and error on a garage door or wall, then test it on the road.
Old Apr 4, 2008 | 02:31 PM
charmz's Avatar
charmz
Is there a certain distance away from the wall you are supposed to be?
Old Apr 4, 2008 | 03:00 PM
Solo_D33A's Avatar
Solo_D33A
taken from HIDPlanet forums
Originally Posted by linuxglobal
I came up with this diagram a while back. The others agreed it was accurate as a guide. The only value that may vary includes the width between the beams (pic says 3-4 feet) however that varies by each vehicle.
I think it should be fairly useful for members that want to use an aiming guide instead of asking around each time.
Drops from red line are the following.
DOT:2.1-2.5 inch
ECE: 3 inch
Good luck
BTW, it's for HIDs, but it's the same concept with halogens
Old Apr 4, 2008 | 04:12 PM
SeattleGS400's Avatar
SeattleGS400
Default Factory Headlight Aiming Instructions
See this thread (post #5) for the factory spec adjustments in a PDF format:
https://www.clublexus.com/forums/sho...t=headlight&#5
Old Apr 4, 2008 | 06:23 PM
Chumacher's Avatar
Chumacher
the distance so that you can see.
lol
Old Apr 4, 2008 | 06:36 PM
charmz's Avatar
charmz
Thanks!
This is exactly what I was looking for
JCtx
RC F (2015-present)
Jul 21, 2018 10:35 AM
bobthelee
RC - 1st Gen (2015-present)
Nov 6, 2015 06:10 AM
lexusben
Jul 2, 2012 12:23 PM
stvincent
Apr 15, 2009 06:11 AM
panther_v
Lighting
Jun 18, 2004 10:32 AM
