Check Engine Light - P0430
Old Apr 19, 2010 | 05:58 PM
  #31
CPMD's Avatar
CPMD
Originally Posted by alenga
cpmd;
I went to Allstar to check them out this afternoon. They were able to check and found out that the cat is bad. Unfortunately, they have to order the cat from somewhere for $675 and additional labor. I thanked them and left.
Did you go to the one on W 130th??
Old Apr 23, 2010 | 01:31 PM
  #32
alenga's Avatar
alenga
Yes, I did. That was the closest one for me.
Old Jan 23, 2011 | 07:26 PM
  #33
CMWis300's Avatar
CMWis300
Po430 code fix. I battled this for a month and came up with a good cheap fix. I had the po430 code on a 2002 IS300. The cheap fix is to tie both of the bank 1 & 2 sensor 2 input wires at the ecu to the bank one sensor 2 output at the ecu. I used one gold plated butt splice connector at the ecu plug. You must leave both sensors and wiring in place good or bad for the heater load and bank one o2 sensor 2 must be good. You can find the pin out wiring diagram online at o2simulator.com. I feel as though it is a design flaw that everyone over 100K will have to deal with. You can spend thousands on cats and o2's and labor or a 20 cent butt splice connector. Hope this helps everyone.
anissaanne
Feb 18, 2017 09:40 AM
The2JZFTW
Mar 23, 2012 09:15 PM
sflexusman
Oct 14, 2011 09:34 AM
shajbot
Jan 29, 2009 01:29 AM
kino1161OL
GS - 1st Gen (1993-1997)
Mar 14, 2006 07:38 AM
