Random CEL, bad O2 sensors?
Old Jan 28, 2009 | 08:03 PM
shajbot's Avatar
shajbot
Default Random CEL, bad O2 sensors?
What are some thoughts on this?
Old Jan 28, 2009 | 08:21 PM
dAng_bAy's Avatar
dAng_bAy
if it's random, probably bad gas. if it comes on after 2 drives cycles and stays light every time you reset the ecu, check the codes. if the codes for 2 heated oxygen sensors, check or replace your plugs.
Old Jan 28, 2009 | 09:06 PM
madmax98's Avatar
madmax98
what do u mean by random? does it flicker or disappears afetr a while? try to get the code, otherwise there's no telling. probably a loose connector or bad ground...
Old Jan 28, 2009 | 11:22 PM
shajbot's Avatar
shajbot
I always pump 91 from Sams Club, I think they sell reliably "good" gas.
CEL comes on randomly and resets when I restart the engine.
One thing though, it does tend to come on when I cruise at relatively same speed (no cruise control).
Timing belt, spark plugs just got replaced, though this started happened way before I have these maintenance done.
Old Jan 29, 2009 | 01:29 AM
madmax98's Avatar
madmax98
when it happens read the code, that's gonna be your best bet to solve this quickly and easily...
STREETGS
Dec 26, 2019 02:34 PM
massakill
Nov 3, 2018 08:06 PM
OG Dada
Feb 10, 2015 02:47 PM
13loody
Performance
16
Feb 15, 2011 12:45 PM
