will these fit stock struts?
Old Dec 2, 2007 | 10:00 AM
phillygs3's Avatar
phillygs3
Default will these fit stock struts?
just wondering will these fit stock stuts ? and does any one have pics with these springs installedhttp://www.optionimports.com/tnf024-31.html( tunabe nf-210 springs)
Old Dec 2, 2007 | 10:07 AM
GSteg's Avatar
GSteg
Stock shocks will not last that long with the Tanabe NF-210. If you want something that lasts longer and rides comparable to soft, then go for the KYB GR-2. If you want something stiffer that will last a lot longer, go with the bilstein HD shocks.
Old Dec 2, 2007 | 11:00 AM
toeb's Avatar
toeb
NF210'S ON STOCK STRUTS!!
HOPE THIS HELPS YOU OUT SOME!!
Old Dec 2, 2007 | 11:54 AM
phillygs3's Avatar
phillygs3
any rubbing at all what offsets? tire size?
Old Dec 5, 2007 | 08:39 PM
toeb's Avatar
toeb
20x8.5+35mm f. 245-35-20, 20x10+40mm r. 255-35-20. it does rub a little in the front but only on hard dips, its just the plastic splash gard in the finder well. it would take a heat gun and about 10min to fix! (i dont drive the car alot so ive been lazy). i plan to change the rear size to 275 30 20 its better suited for the car if you dont like the streched look! i had the 255's laying arround so i thought i would wear them out first!!!!!
Old Dec 5, 2007 | 09:15 PM
Nazar's Avatar
Nazar
How about some coilovers?
Old Dec 6, 2007 | 12:24 PM
phillygs3's Avatar
phillygs3
thanks for the info
ScottIS
Suspension and Brakes
May 30, 2012 06:39 AM
DanMan
Jan 20, 2009 07:52 AM
ErickGS300
Dec 24, 2008 09:14 AM
Todd Edge
Feb 28, 2008 07:41 PM
