Anyone rocking 19/21s ?
Old Oct 15, 2007 | 08:57 PM
VipDout's Avatar
VipDout
19x11.5 -51
Default Anyone rocking 19/21s ?
I searched and didnt see anything ... was wondering if anyone has seen this combo of wheels ?
19x9 and 21x10 in the rear ? ectt. ?
if anyone had photos that would be Nice thanks !
Old Oct 15, 2007 | 09:01 PM
carbongs's Avatar
carbongs
21" wide tires?
Old Oct 15, 2007 | 09:11 PM
VipDout's Avatar
VipDout
19x11.5 -51
nahh nahh Like a 19x9 in the front ... and a 21x10 in the rear ...
Have you seen this combo before ? had no luck searching
Old Oct 15, 2007 | 09:22 PM
speedaddic's Avatar
speedaddic
that would definately look different. I wonder what a quick photoshop would look like.
Old Oct 15, 2007 | 09:48 PM
V8_Aristo's Avatar
V8_Aristo
Bippu
One problem I can see with this set up is the different overall diameter between the 2 tires, not unless you run a very fat tire in the front. Which kinda defeats the purpose of having a staggered diameter sizing.
Old Oct 15, 2007 | 10:54 PM
dle's Avatar
dle
man, i dont know about that one.
Old Oct 15, 2007 | 10:56 PM
Caoboy's Avatar
Caoboy
Don't do it. Rock 19's with a wide width and lower offset, and it'll look perfect. you can't go as low on 20's.
Old Oct 15, 2007 | 11:02 PM
VipDout's Avatar
VipDout
19x11.5 -51
very true ...
But With the kit I am rocking now It would fill the fender well better with the design ...
wonder if anyone has seen this either ... or anyone good at photoshop ?
Old Oct 15, 2007 | 11:04 PM
Caoboy's Avatar
Caoboy
John at VSC (the guy with teh original jp gs) was rocking 19" scaras. Looked perfect then, he's got the same stuff you do. It'll look fine with 20's i wouldn't go any bigger than that though.
Old Oct 15, 2007 | 11:06 PM
VipDout's Avatar
VipDout
19x11.5 -51
I'll search as see what i find
Old Oct 16, 2007 | 01:56 AM
Caoboy's Avatar
Caoboy
Go with some crazy offset 19's....you'll be much happier. and you'd definitely be able to run a 35 series tire for a bit more cushion, as with a 20/21 you'd need at least a 30/25 profile which can get ugly...
Old Oct 16, 2007 | 06:55 AM
bluelex's Avatar
bluelex
With 21 inch wide tires you only have 3 choices available. 255/35/21 255/30/21 & 295/25/21 so if you went with a 10 wide in the rear you would have to run a stretched 255 to make it work. Unless you just go wider in the the rear to make it work. I have 21x11 with a 295/20/21 and its perfect, not to beefy looking and not stretched. By the way i don't think 19's front and 21's rear would look good. maybe do 19/20 or 20/21 or heck with it just go 21/21.
Old Oct 16, 2007 | 11:07 AM
VipDout's Avatar
VipDout
19x11.5 -51
Well Being bagged helps too ...
Its a good Idea , Esp if you are fitting a 21x11 w. a 295/20/21
I should look at the 19/20 combo ... Just wondering if anyone had did this before ..
thanks guys
Old Oct 16, 2007 | 04:13 PM
tommyGS3's Avatar
tommyGS3
19/19 20/20 or go with Bluelex 21/21
to me 19/21 look funny
Old Oct 16, 2007 | 06:57 PM
VipDout's Avatar
VipDout
19x11.5 -51
question is ... is have you even seen it done ?
on a bagged GS ?
thats why I asked
Lexus@17
Dec 24, 2009 06:19 PM
5t341th
Sep 15, 2009 02:00 AM
BklynJay
Oct 25, 2008 12:51 AM
Neo300
Jan 10, 2008 09:42 PM
mja
Feb 20, 2007 12:57 PM
