Led tail light install question
Old Oct 9, 2007 | 06:19 PM
yoda86ed's Avatar
yoda86ed
Default Led tail light install question
I installed my led tail lights today, looks great but I noticed after the install my tail light out light on the dash is on. I check all the lights everything is fine but I was wondering if anyone else had this problem. thanks
Old Oct 9, 2007 | 06:20 PM
4ntvings's Avatar
4ntvings
where are you LEDs from? If Carson, you should already know it triggers that warning light. Don't worry, this is a common issue and nothing to be worried about, unless you wired your lines funky.
Old Oct 9, 2007 | 06:33 PM
yoda86ed's Avatar
yoda86ed
thanks Iam not so worried now
Old Oct 9, 2007 | 06:43 PM
chrispy's Avatar
chrispy
If it bothers you just pull the bulb from the dash.
Old Oct 9, 2007 | 07:07 PM
GS FONZy's Avatar
GS FONZy
actually, carson's were revised a long time ago, so you would not get a dash light. I think they even revised the inners too. i have a dash light because of the inners, so I just pulled the bulb
Old Oct 10, 2007 | 06:37 PM
DarKnight's Avatar
DarKnight
Make sure the lights come on when you turn the lights on and also when you press the brake, you could have connected them wrong. I don't think the outers should set off the tail light bulb out indicator, only the inners.
Old Oct 11, 2007 | 05:56 PM
GS FONZy's Avatar
GS FONZy
i don't think they can be installed wrong, they have plugs that are one way. the reason why the dash light comes on is because he got them from ebay or got the unrevised from carson (used from someone).
Old Oct 12, 2007 | 01:38 AM
DarKnight's Avatar
DarKnight
I say that because when I first got mine I plugged them in wrong and had the light out indicator on the dash and the lights wouldn't come on when I pressed the brake so I switched the plugs and the light out went away and the lights came on when I pressed the brake. Remember that the brake light is a double filament bulb so the led's work the same.
Old Oct 12, 2007 | 08:46 AM
Saiji's Avatar
Saiji
Mine's are pretty cool. Only when I step on brakes, the light comes on. But then at night it's on constantly...
Old Oct 12, 2007 | 02:59 PM
GS FONZy's Avatar
GS FONZy
that because they turn on (night, brake press) and don't read the same resistance as a regular bulb would.
Old Oct 12, 2007 | 05:20 PM
awwwmayeen's Avatar
awwwmayeen
anyone have problems w/ the tails of only the brake light working, or nighttime light but never both. just one or the other. i tried plugging them in every way possible and still the same, the lights would light up at night, but brakes wouldnt work, or plugged differently the brakes would work but not the ones for night. thx.
Old Oct 13, 2007 | 07:52 AM
Bigbea's Avatar
Bigbea
I'd not worry about it. Grow to love your little green dash light like I do...
Old Oct 13, 2007 | 08:57 AM
davezaristo's Avatar
davezaristo
So once you plug the OEM tailight back, will the little green dash light go away?
Old Oct 13, 2007 | 09:09 AM
corkycal's Avatar
corkycal
yes unless you still have the inner leds hooked up. if you put back everything back to oem, the light will go off.
Old Oct 15, 2007 | 08:01 AM
Saiji's Avatar
Saiji
man, my right, right inner, left inner lights dont work at night!!!!!!!!
Only when i step on the brakes...can someone pin point to me whats wrong? Thanks
Bgw70
Feb 25, 2017 07:26 AM
G_ride
Dec 27, 2010 12:32 PM
EvilAristo
Oct 12, 2009 10:57 AM
JemmyTran
Oct 12, 2008 12:08 PM
dboyz85
Apr 1, 2007 07:18 PM
