Speedsensor gon bad?
Old Jun 6, 2007 | 01:37 PM
cr00klyn71's Avatar
cr00klyn71
Post Speedsensor gon bad?
The speedo on my Brothers GS would work then out of nowhere it sits on Omph while driving on the hwy. Our question is where is the speed sensor located on the car, and also what is a ballpark figure to replace this part?
Thanks in advance.
Old Jun 7, 2007 | 12:47 PM
cr00klyn71's Avatar
cr00klyn71
Nobody knows, guess we gonna have to take it to the dealership. Time to break out the wallet.
Old Jun 9, 2007 | 09:17 AM
sjpobox's Avatar
sjpobox
your going to need a new instrument cluster. ive replaced a few of them but never knew how much we charged.
Old Jun 10, 2007 | 08:16 AM
Lexmex's Avatar
Lexmex
Speed sensors are usually located near each wheel themselves, my good friend Salimshah and I were talking about this on the RX300 here (with photos), https://www.clublexus.com/forums/sho...d.php?t=285023
I did notice a little pickup after I cleaned them off with carb cleaner.
Old Jun 10, 2007 | 08:25 AM
sjpobox's Avatar
sjpobox
a bad speed sensor will throw a vsv code, since you did not mention the light was on led me to beleive the instrument cluster itself was at fault. where ever you go if they have a lexus scan tool they can verify if the speed sensor is bad.
Old Jun 10, 2007 | 08:39 AM
Lexmex's Avatar
Lexmex
shawnjohn9,
You are right. The cluster is usually the issue on this one.
Old Jun 10, 2007 | 09:48 AM
LEXUS_KID's Avatar
LEXUS_KID
is it recording your miles ?
Old Jun 10, 2007 | 11:36 AM
mikevanle's Avatar
mikevanle
I guess on the Lexus the speed sensors are near the ABS right?
On the Supra (and other Toyota's) there's usually a gear driven piece that goes into the tranny.
Old Jul 2, 2007 | 09:13 PM
cr00klyn71's Avatar
cr00klyn71
The check light actually came on after a while, and the speedo is stuck. Can't seem to locate the sensor. Isn't it usally on the tranny?
Old Jul 2, 2007 | 10:13 PM
JeffTsai's Avatar
JeffTsai
The speed sensor is located on the tranny. There are also ABS wheel speed sensors on each wheel. The ecu relies primarily on the speed sensor on the tranny. I'm not sure if it reverts to the ABS sensors or not if the sensor on the tranny fails.
lsvtec
Jan 25, 2016 05:41 AM
MattLS400
17
Apr 8, 2014 10:49 AM
Jetkillr
IS - 1st Gen (2001-2005)
Feb 7, 2012 03:38 AM
rocampo
Oct 26, 2007 06:43 PM
