door lock actuator repair
Old Mar 16, 2007 | 06:31 PM
angus's Avatar
angus
Default door lock actuator repair
OK, so i've been reading that the actuators are a problem,mine was,anyways I've found out how to fix them(saving myself 200 dollars) if anyone is interested,pm me
Old Mar 16, 2007 | 06:35 PM
movinquick's Avatar
movinquick
how? share the wealth..
Old Mar 16, 2007 | 06:52 PM
angus's Avatar
angus
OK- so once you remove the actuator assy. you take off the actuator from the latch assy. then ur gonna have to force the acuator open by prying , its glued together. dont worry about gluing it back its held together by two screws,you will see that there is a motor inside similar to a a slot car motor(i have lots of exp. with these) ur gonna need to open this up,once open you'll see that the brushes are probably worn but that won't matter much,just re-tension the brushes,then clean the cummutator and reassemble.once this is done pull out the gear (the big one) and discard the spring,then reassemble the whole thing and youll see it works again!!!!
ps. im trying to find just this motor cause im sure its worth like $2
Old Mar 16, 2007 | 08:34 PM
corkycal's Avatar
corkycal
did you take any pics while you took the actuator apart? it's kind of hard to follow what you did.
it's good to know that these can be rebuilt but most members here just buy new ones and not have to deal with it again.
Old Mar 16, 2007 | 10:20 PM
Trippinond's Avatar
Trippinond
I've done something similar to this on a honda accord before...Now i have this problem on two of my doors but have an appointment at lexus monday to get them fixed (Thank god for warranty)
Old Mar 16, 2007 | 11:30 PM
owali's Avatar
owali
Good writeup. Pics would help a lot
Old Mar 17, 2007 | 12:23 AM
angus's Avatar
angus
i dont really think pics are necessary, the thing has like 3 moving parts inside - pretty self explanitory once you open it!!!
Old Mar 17, 2007 | 12:30 AM
UDel's Avatar
UDel
Pics and a little more detail on steps would definitely help just to make sure we are doing it correctly. Can you give a little more detail like how you got to them and what you needed to remove or do like keep the window rolled up/down, what you unscrewed, any problems getting the actuator out or putting it back,etc. I will probrably try this but I am a little nervous I might screw something up.
Old Mar 17, 2007 | 07:53 AM
o2GS43o's Avatar
o2GS43o
If mine goes out again, i just might have to do this... Thanks...
Old Mar 17, 2007 | 10:11 AM
sbgs400's Avatar
sbgs400
when my actuator failed it was because the connector on the cable broke and nobody sells the cable separately. i know others have had the same failure point.
Old Mar 18, 2007 | 01:58 AM
OutlawTita's Avatar
OutlawTita
I kept the actuator I replaced since it still worked partially. That is probably what was wrong with mine and it may be fixable.
Old Mar 18, 2007 | 09:25 AM
angus's Avatar
angus
if you send me yours then i"ll fix it and take pcs,then send it back
mbenz80
GX - 1st Gen (2003-2009)
45
Nov 3, 2019 01:18 PM
TTurboPimp
Feb 15, 2014 02:54 PM
srgone
Aug 23, 2011 10:05 AM
artbuc
RX - 1st Gen (1999-2003)
Jul 29, 2010 07:38 AM
fblonk
Nov 4, 2009 08:45 PM
