Guys, need help !!!
I got a 02 gs430 and drove to work today and my AUDIO system isn't working (radio, tape or CD). Looks like i'm getting signal for the AM/FM radio (i see ST on the display), but i can't hear anything. SO i tried to play CD and still cant hear anything. Before i go to the dealer (which i'd rather not), any ideas on what i need to check for?
thanks all for the help.
I guess by now you have switcd off your car and pulled the keys out.
Try turning the car on and there is a more than 50% chance that every thing has cleared out. Almost like re-start on the computer.
If the problem persists then, there is an actual problem.
Salim
Salim
You didn't say if you had a non-ML system or not. If it's a ML system more than likely it maybe your ML amp. If so, the dealer will charge in the excess of $900.00 for a replacement. I have had several friends with GS w/ML and they had the same problem. We purchased amps off ebay and installed them ourselves and problem solved. They had the same symptoms as you are having. If you have a non-ML system I can't help you. Good Luck.
sorry guys, yup i do have the Levinson system.
few questions:
1. what exactly do i look for in ebay (ML Amp)? is there a specific ML Amp i need to get?
2. how can i make sure that the AMP is my problem? any checks i can do myself?
3. is there a site on how to replace the Amp myself?
thanks again fellas.
few questions:
If you have the ML system w/Navigation, the amp in in the trunk on the right side underneath the Navigation Computer. It takes 10-15 minutes to remove and re install. Can't find the the stock number but check here on:
http://www.trademotion.com/partlocat...?siteid=213808
Or check the radio section here on for more info. Again very easy to replace.
thanks guys.
i did a search and looks like a few ppl have had this issue on the radio.
Looks like i need to replace my ML Amp.
is there a specific AMP i need to check for in ebay? any specs i need to look for in the AMP?
thanks again.
thanks again.
IF it's your amp, why not replace it with an aftermarket one that would perform better and cost less? All you would need is a line in converter and tap into some wires (which is already conveniently ran to your trunk).
Gapxguy described exactly what i want to do. Has anyone done that - i.e., replaced the ML AMP and whatever else needs to be replaced as an alternative to buying a really high dollar replacement amp? Thx!
Big Mack
alexchris1
Apr 24, 2019 03:51 PM
tmotto
Feb 21, 2014 04:25 PM
hoyty
Dec 18, 2003 07:06 AM
