Need help with uncommon problem.
Old May 18, 2006 | 07:23 AM
maintrain's Avatar
maintrain
Default Need help with uncommon problem.
I was driving to work and all of a sudden, my accelerator pedal goes to the floor. I pull over on the shoulder a pop the hood. I can see under the engine cover where the throttle cable has disconnected from the throttle body. It seems that the plastic the holds the cable on the black spring loaded part connected to the throttle body has broken. My question is, can the black spring loaded part be replaced without replacing the entire throttle body? I already know the the throttle body is $$$$!!!
Please help!
Old May 18, 2006 | 07:27 AM
Lexbox's Avatar
Lexbox
I have no idea about the answer but I just wanted to say that is crazy.
Old May 18, 2006 | 07:29 AM
maintrain's Avatar
maintrain
Exactly! I called Hennesy Lexus and the tech said he has never seen this happen before!
Old May 18, 2006 | 08:14 AM
maintrain's Avatar
maintrain
bump...
Old May 18, 2006 | 08:49 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
wow that insane. So you were just driving? Not flooring the pedal??
Old May 18, 2006 | 08:53 AM
maintrain's Avatar
maintrain
Just driving about 70 mph, pressed the pedal to pass a semi and nothing! Just got off the line with the dealer and looks like I can order the Accelerator lever assembly part # 22060-50011. I'll let you guys know how it works out.
Old May 18, 2006 | 10:04 AM
bighitbike's Avatar
bighitbike
That would be really scary. At first I thought it just stuck to the floor then that would just be insane!!!
Old May 18, 2006 | 10:45 AM
Kharizma's Avatar
Kharizma
wow.. that's pretty crazy man.. good luck with the fix... is your car still under warranty? i'd get on their case about it like you'd lose your life and etc. lol
let us know the cost and etc. and if they have some explaination for you!
Old May 18, 2006 | 11:07 AM
Dx3's Avatar
Dx3
Epoxy that biiatch back together JK.
Jonny
Old May 18, 2006 | 11:49 AM
DASHOCKER's Avatar
DASHOCKER
That part is about 270 bucks shipped from Carson. Had to replace that part myself https://www.clublexus.com/forums/sho...ighlight=p1120
Old May 18, 2006 | 12:33 PM
maintrain's Avatar
maintrain
I actually read this post earlier. The local stealer is selling me one for $280. Maybe those jackrabbit take offs just wore it out! Do you have to remove the entire throttle body to replace it?
Old May 18, 2006 | 12:48 PM
DASHOCKER's Avatar
DASHOCKER
Not at all, it just plug and play since there are prongs on the part. The the throttle cable just snaps in place. 10 minute job.
Old May 19, 2006 | 11:06 AM
maintrain's Avatar
maintrain
All is well now. Thanks.
Helogadget
Mar 14, 2025 02:35 AM
articmonke
May 21, 2013 08:40 AM
RX300tina
RX - 1st Gen (1999-2003)
Jan 17, 2008 07:00 PM
Spyder78
Performance
Jul 26, 2006 08:03 PM
TRiis2004
Mar 18, 2002 03:26 PM
