Replace fuel pump?
Old May 12, 2006 | 09:25 AM
Dx3's Avatar
Dx3
Default Replace fuel pump?
Guys,
I am pulling out my Walbro 255lph fuel pump and going back to stock. My stock one has 110k on it. Do you think I should buy a new OEM one or just put my old one back in. It never had any problems before I took it out.
Thanks,
jonny
Old May 12, 2006 | 09:39 AM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
I would get a new one for peace of mind so nothing will happen down the road..
Old May 12, 2006 | 10:48 AM
LEXSOOS's Avatar
LEXSOOS
It depends how much you have to spend for brand new OEM, if it's way more than 150-200, i would go with old FP, they are built to last long time,
Sugestion: if you decide to go with old FP, sink FP in bucket filled with fuel for about 1 or 2 days before installation
Old May 12, 2006 | 11:17 AM
Dx3's Avatar
Dx3
Hey man,
Even with CL discount it is still $248. I think I will just put the old one back in but I will use your trick. What exactly does that do?
Thanks man,
Jonny
Old May 12, 2006 | 11:57 AM
LEXSOOS's Avatar
LEXSOOS
Originally Posted by Dx3
Hey man,
Thanks man,
Jonny
If FP was sitting in your garage for awhile, it totally dried up, so before you put it back on you want reduce risk of FP running dry when installed, this is precaution you can take in advance instead of ending up with new FP couple days or weeks later.
Note: I can't guarantee that FP will be running fine even if you do what i've suggested, like i mentioned before this is precaution you still have time to do, it's better to be on safe side than sorry
P.S. What's the reason for swiching FP back to stock?
Old May 12, 2006 | 03:30 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Hey man,
Thanks man,
Jonny
I would just put back the old one... You dont really hear about fuel pump failure around here... knock on wood.
Old May 12, 2006 | 11:47 PM
JeffTsai's Avatar
JeffTsai
I'm guessing that he probably doesn't like the noise of the Walbro. Those high pressure/high flow pumps are quite noisy. My friend has dual fuel pumps (I think walbro's) in his Supra and there is a loud high pitch whine all the time.
Old May 13, 2006 | 06:12 AM
Adam2562's Avatar
Adam2562
my GS was at Lexus a few weeks ago cause my fuel pump died at 99k..... i was surprised... but i had another one put in... i got it for $230 i have a buddy at Lexus tho... i'd buy a new one and replace it
Old May 13, 2006 | 10:02 AM
cliffud's Avatar
cliffud
Former Vendor
agreed. if you're going to do the work already (unless the labor is not intensive at all) then go with the new fuel pump.
if the labor is easy like brushing your teeth- go with the old one and swap for a new one if it breaks.
Old May 14, 2006 | 09:33 AM
Adam2562's Avatar
Adam2562
labor at Lexus was juts as much as the part itself actually a tad higher
mrmcd982
Jul 4, 2019 08:30 AM
Nad1370
RX - 1st Gen (1999-2003)
15
Jun 5, 2019 04:12 AM
bruceb58
Jan 23, 2012 10:56 AM
Halon
Sep 28, 2011 06:38 PM
phild
Aug 12, 2009 09:16 AM
