Bad heads?
Old Jul 11, 2005 | 01:40 PM
sxwk12's Avatar
sxwk12
Default Bad heads?
How can you tell if your head needs to be replaced? Is there any sign?
Sidney
Old Jul 11, 2005 | 02:21 PM
TLW's Avatar
TLW
whats going on with the car Sid
sounds like your having alot of trouble after the timing belt change
Old Jul 11, 2005 | 04:42 PM
blacksc400's Avatar
blacksc400
Car Chat Moderator
engine shakes real bad, shut off itself, and make no power...
but head always can be remachined instead of replace. But I hardly see any Lexus V8 has head problem unless overheating toooo baddddd!!!
Old Jul 11, 2005 | 05:47 PM
TLW's Avatar
TLW
hes got the 300
Old Jul 11, 2005 | 06:26 PM
LS4fun's Avatar
LS4fun
Sidney
Are you talking about the head gasket?
Maybe the timing of your car is off?
Old Jul 11, 2005 | 06:33 PM
sxwk12's Avatar
sxwk12
Yeah you're right GTFM, since the timing belt change I have had the high idling problem, p1349 and VSC and VSC OFF lights lit up. Took it to the dealer Friday and they said I need a new head. They want $4000.00 (four thousand). I told him he was full of it and to just put it back together and I will get a second opinion. My mistake was telling them upfront that I did the timing belt change myself. The other day when I went in, they said they needed 6 hours of diagnostics @ $90.00 an hour. I told them no way. So a few days later they cut it down to 2 hours. Sounds like a lot of BS right there. Today when they called me, they said they would only charge me 1 hour diagnostics. I'm greatful for that but there is a whole lot more behind of this that is too long to get into. I know, and they know that I will NEVER take my car there again. I will just drive it 100 miles to next closest Lexus dealer, Hendrick Lexus in Charlotte. I have an appointment Monday with them.
This tech here is the one that also said that i did not "preload" the camshaft crank. But in my other thread, no one could even tell me what that meant. So once again, I call BS.
Sidney
Old Jul 11, 2005 | 06:43 PM
WIZARDJ's Avatar
WIZARDJ
Default Watch Out For Fakes
No Matter Where You Go You Always Are At There Mecy.....its Great When You Been Wrenching For Years And You Know Whats Behind All The B.s. As You Put It....educate Yourself More Nad Try Again..at Least I Would. My Two Centsss J :d
Old Jul 12, 2005 | 06:08 AM
Jugg_head's Avatar
Jugg_head
Any chance you swapped you spark plug wires around by accident ? If not, kinda sounds like timing.
Old Jul 12, 2005 | 06:20 AM
sxwk12's Avatar
sxwk12
Nope, it's not the spark plugs. This was happening before I changed those. What I am hoping is that the timing was off just enough to make it idle but not do any damage and after the dealer puts everything back together and gets it on time correctly, I am hoping the problem clears up. That would be the funniest thing to get my timing fixed for $85.00! But we'll see today when I pick it up.
Sidney
blazinktm
GX - 1st Gen (2003-2009)
Sep 6, 2018 04:55 PM
2j300
Oct 21, 2012 12:23 PM
ISFFUN
Jan 15, 2012 10:49 PM
Supra Dr
May 17, 2010 09:16 PM
sxwk12
Apr 23, 2005 11:59 PM
