Power Door locks not working properly
Old Dec 16, 2015 | 11:40 AM
  #31
bruceb58's Avatar
bruceb58
Originally Posted by fickit
Would you mind posting the Ebay link or PM if its against rules to post outside links on the forum?
I have a 01 GS430, the motors should be the same in all models right?
http://www.ebay.com/itm/4-pk-MABUCHI-CAR-DOOR-LOCK-MOTORS-DIY-ACTUATOR-REPAIR-Toyota-Lexus-Honda-Ford-/111503859035?pt=Motors_Car_Truck_Parts_Accessories&hash=item19f625dd5b
There is a whole thread in the stickies that describe how to repair these. You will also need a small gear puller.
http://www.ebay.com/itm/Original-Walkera-BOX-SET-Motor-Gear-Puller-Turnigy-Align-Mini-CP-Master-CP-/161255544548?pt=Radio_Control_Parts_Accessories&hash=item258b9456e4
Everyone needs to read this.
https://www.clublexus.com/forums/gs-...ators-diy.html
Old Dec 16, 2015 | 02:22 PM
  #32
bruceb58's Avatar
bruceb58
Originally Posted by LexusK
All 4 of mine are out now lol. For some reason, the rear passenger was not locking even when I tried to manually lock it. I ended up putting the child lock on, which worked and kept the door from opening up. However, now that I think about it, that might have been a bad idea, because I can't open it from the outside or the inside....... What do I do?!?!?
Yep...bad idea. The only way I van think that you re going to get in is take the door panel off while the door is closed ant that is going to be difficult.
Old Dec 16, 2015 | 06:50 PM
  #33
Metlupass2's Avatar
Metlupass2
Can you just buy the whole actuator rather than the motors and gear pullers?
http://www.ebay.com/itm/6Pin-Front-L...ZTq9E7&vxp=mtr
Old Dec 16, 2015 | 10:24 PM
  #34
bruceb58's Avatar
bruceb58
Sure you can. Just have to find all 4 since they are all different.
Personally, I would replace the motor in your current Lexus one than buying that Chinese piece of who knows what.
The hardest part of the job is taking out and installing the actuator. The easy part is replacing the little motor.
Old May 6, 2016 | 02:22 PM
  #35
kdooley08's Avatar
kdooley08
Default Found a details video how to replace the actuator motor
Check it out, step-by-step video how to replace the actuator motors:
Part 1:
Part 2:
I'll be giving this a try when the weather is nice and I have some time...
Old May 6, 2016 | 02:43 PM
  #36
senovins's Avatar
senovins
Default door locks
Because I have soft door closings, my Lexus dealer wanted $1100+ to fix them. I did not do it.
Old May 6, 2016 | 02:56 PM
  #37
sakataj's Avatar
sakataj
You know these have been posted many, many,many times.... including in here for the first time
which is the MAIN thread for the door actuators
welcome to the boards but before we post why dont you look over this thread,
https://www.clublexus.com/forums/gs-...iy-thread.html
it has almost everything you need (and everything else can be found by searching....yes actually searching)
Old May 10, 2016 | 05:56 AM
  #38
Rsharp715's Avatar
Rsharp715
My rear door locks unlock with the fab, but will not lock. They will lock and unlock with the drivers side door lock. They will also lock manually. Any advice?
Old Jul 1, 2018 | 09:36 AM
  #39
drangel's Avatar
drangel
I am new to clublexus and am just now experiencing this issue for my 2000 ES300. Is replacing the motors in the actuator the best way to fix this issue for good?
Old Jun 24, 2019 | 03:23 PM
  #40
Thomasbjoe's Avatar
Thomasbjoe
So my doors make some kind of clocking noise when the lock/unlock button is pressed on the driver side but none of the doors lock/unlock.
I don't have the master keys i use my spar to lock unlock the doors and that works fine. Is this still actuator you think? its just weird that its all the doors but there is noise letting me know electronically something is happening
Old Jun 24, 2019 | 08:57 PM
  #41
lexo98's Avatar
lexo98
Sounds like the actuators are done
Silvermtb6
Jul 15, 2012 11:53 AM
markaus
RX - 1st Gen (1999-2003)
Nov 14, 2011 10:48 PM
tyncobb
Maintenance
Aug 29, 2010 06:15 PM
tyncobb
Aug 4, 2009 10:26 AM
Petrie2001
Sep 15, 2006 12:52 PM
