Memory button on door doesn't remember seating position -only steering and mirrors
Old May 8, 2005 | 04:28 PM
Threxx's Avatar
Threxx
Default Memory button on door doesn't remember seating position -only steering and mirrors
Weird... did I change a setting or did something break 'partially'. It's weird to see electronics only break partially, though. You'd figure it would either work or it would.
My seat's position can be adjusted easily as always via the buttons, so can the mirrors and steering wheel... but when I go to adjust back to my memory #1, it only adjusts the steering wheel and mirrors. Not the seating position. I tried again getting my perfect settings and then setting the memory button same as I always have; then moved everything around a bit. No dice, it set everything back to the memory settings except the seat.
So is there a setting that allows you to change only the mirror and steering wheel position via the memory button, or did some weird glitch occur?
Old May 8, 2005 | 04:31 PM
Threxx's Avatar
Threxx
Weird... I just went out to my car again right after posting this to play around with it a bit more; thus reinserting my key, but only minutes later. And everything worked again.
Old May 8, 2005 | 04:32 PM
dmodstl's Avatar
dmodstl
Hmm. Are you doing all this while in Park? Also, when you program the settings are you hearing a beep?
Old May 8, 2005 | 04:34 PM
dmodstl's Avatar
dmodstl
Post
Oops. Nevermind.
Old May 8, 2005 | 04:38 PM
Threxx's Avatar
Threxx
Yes, I was in park, and yes I heard a beep. Everything was normal except the seat wasn't moving.
Old May 8, 2005 | 09:14 PM
jonathancl's Avatar
jonathancl
Did you have your foot on the brake?
Old May 9, 2005 | 08:32 AM
chicagoblknazn's Avatar
chicagoblknazn
Was pluto aligned with Mercury?
Glad it all worked out on it's own. That would have bugged me.
Old May 9, 2005 | 08:42 AM
Threxx's Avatar
Threxx
Interesting point... would that make a difference? I don't see why it should though... if you're in park then you aren't going anywhere anyway.
Old May 9, 2005 | 09:33 AM
jonathancl's Avatar
jonathancl
You and your silly logic.
I just tried it: the seat will not move when your foot is on the brake, even if you're in park.
Procedure:
Put car in park.
Move seat away from memory setting.
Depress brake.
Push memory button.
Seat doesn't move.
Release brake.
Push memory button.
Seat moves...magically.
edit: btw...have you sold your daizen sways? I'm told that's what I need to properly complement my L-Tuned suspension.
Old May 9, 2005 | 02:35 PM
Lettuce's Avatar
Lettuce
is your foot off the brake pedal?
Old May 9, 2005 | 04:00 PM
dmodstl's Avatar
dmodstl
Post
LOL. I've had one of those Mondays. That comment made me laugh.
Had to be there I guess.
Old May 9, 2005 | 08:13 PM
kpuri's Avatar
kpuri
Mine did the same thing today!
I wonder if it will only adjust the seat if u push the button before u insert the key?
I will try again in the morning, it may just be a Monday thing
doodoo
Apr 1, 2025 06:39 PM
Broncosi
Jun 5, 2019 05:34 PM
Maskvich
Jul 15, 2017 02:30 PM
thelew67
RX - 3rd Gen (2010-2015)
Jun 25, 2014 10:25 AM
PClarkccg
Jun 14, 2005 11:17 AM
