Stock spoiler question
e-man
i think you should talk to carson toyota about it
Is there someone out there with the stock spoiler who would be willing to post pictures of the inside of their trunk lid (preferably with the liner removed)?
e-man
e-man
otherwise you'll have to buy/borrow a rivet gun. and yes, rivets expand when the gun pops them in.
Riveting 101:
To attach a rivet you use a specific tool called a rivet gun. You drill a hole in the correct place and use the gun to pop the rivet into place, which holds down the spoiler bracket. The gun expands the rivet shaft from behind which is how it's secured. It only goes down less than a half inch behind the trunk lid. This is the least of your problems.
You will also need to cut out a 1/2 " square hole on each side of the trunk lid which allows you to install a threaded plug for a bolt. Finally, you need a third 1/2" diameter hole on the left side to run the electrical wire for the third brake light.
The brackets for the spoiler are mounted on both sides using the rivet, the threaded plastic plug which secures the bolt in place and lastly there is double stick tape.
As if the bolt and rivet weren't enough huh?
The mounting of these brackets is critical cause if they are off even a little bit, the spoiler won't fit or align properly at all. You absolutely need a template and ya gotta do it right the first time.
If you buy a used spoiler, it won't come with that template and the dealer might only provide a template if you buy the spoiler from them, since there wouldn't be any reason to offer the template by itself.
If you really want the factory spoiler, do what everyone else does and exchange the whole trunk lid with someone willing to trade.
This would be an excellent suggestion except look at the back side of the trunk lid where the bolts would need to go. There is another layer of sheetmetal in the way, so it's not like you just reach back there and attach the nut.
I'm not saying it's impossible, but it might be beyond the skill set of what some might think to be a simple DIY install.
HAHA
looks like we're all on the same brain wave here.
If you wanna try it e-man go for it.
Most non-oem spoilers use double stick tape and that's it. I would think that the spoiler would have to be a lot lighter than stock to be able to hold on adequately. The factory builds a pretty hefty and strong wing, so no way would you not do more than use just double stick tape.
As far as how they look different from stock, I'd say yuou'll have to look to others with non-oem wings for that feedback. From what I heard, you can tell the difference and some think they look cheap.
Anyone out there with any personal hands-on experience that would like to weigh in here?
