my car is all over the road .........
Old 09-08-04, 06:59 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
Unhappy my car is all over the road .........
ok since i installed my wheels and my coilovers it seems that iam fighting my steering wheel while driving .I notice that iam 'drifting around' in my lane I have 9" wide wheels in front and this provides a huge contact patch which grabs everything in the road.Does anywone think that the Ltuned steering ecu will help out my problem ?? thanks shawn
Old 09-08-04, 07:28 PM
BA_GS400
BA_GS400's Avatar
sounds like you need an alignment bad! Toe-in and camber are probably out of whack.......
(the reports I've read on the steering ecu around this site are only marginally favorable)
Old 09-08-04, 08:10 PM
lexusondubs
dubsonlexus
i just got a 4 wheel alignment less than 1k ago and i have not hit anything to knock it out of whack
Old 09-09-04, 05:19 AM
lexforlife
lexforlife's Avatar
shawn
2 things i could recc , 1 is you need a front strut bar , whenever you increase the size of the front contact patch area you are putting a tremendous amount of strain on the front end bushings , arms and shock mounts , remember they were designed to work with the contact patch of no more then 235/45/17 and a 7.5 in rim , you are up to 9in with a 245/35/20.. 2 thing is get a toms front lower control brace with the extra link .. that will help the lower control arm stay within its designed range of deflection and tighten things up front nicely
Old 09-09-04, 06:39 AM
joshoowa
joshoowa's Avatar
im sort of on the same boat, im not fighting the bumps too hard like you make it out to seem. i do have to hold the wheel though or it will wack out, i've always assumed it was factoring in larger wheels and my trd sways. havent ppl on this forum complained already about how the steering wheels becomes loose as speed increases? i believe you could possibly tighten the steering wheel colum, i think called a tensionor screw or bolt? btw im running 8.5"
Old 09-09-04, 11:26 AM
BostonGS4
BostonGS4's Avatar
this is nostalgic....
My 00 Civic SI had this problem.... 18s, Tokico 5 ways, ebaichs, front and rear sways....
The low pro tires grabbed EVERYTHING on the road.....on bumpy roads it truly felt like i was fighting the wheel.
I uuuusssuuuaaallllyyy won the battle.
Old 09-09-04, 08:07 PM
lexusondubs
dubsonlexus
yes this is the same as iam dealing with its not the bumps at all
Old 09-10-04, 02:46 AM
00lexondub
00lexondub's Avatar
sell your wheels
Old 09-10-04, 02:14 PM
lexusondubs
dubsonlexus
Originally posted by 00lexondub
sell your wheels
YOU WISH !!
Old 09-11-04, 03:31 AM
LS4fun
LS4fun's Avatar
Don't drive in the rain until this is corrected.....rain will only aggravate the problem.
Old 09-11-04, 08:20 AM
NT2SHBBY
NT2SHBBY's Avatar
I finally got a place to do my alignment RIGHT, after a third time having it royally ****ed up
now I am planted well on the road. And BTW these cars are REALLY sensitive to road imperfections. All it took was a nasty pothole to make my steering wheel and the rest of my car crooked
Johnhav430
01-24-19 05:12 AM
billydpowe
09-17-16 10:17 AM
Moswift
09-08-13 01:30 PM
garfull
RX - 3rd Gen (2010-2015)
01-20-11 02:25 AM
Lvangundy
Maintenance
04-08-03 10:33 AM
Quick Reply: my car is all over the road .........
