my dealer told me that he needs to replace GPS antenna.. due to GPS not working correctly all the time.. some times it shows me driving over wather, My back window is tinted.. so now i am just trying to figure out how this is going to happen ?
Sounds like Rear Window Tint = History
If it's metallic tint it may be causing part of the problem.
If I remember correctly, a previous post said that the Nav antenna is located somewhere under the rear deck, and not in the window. I never really actively looked for it, so I can't confirm that.
I have never found mine either but I have noticed 2 bumps up in the front of the dash close to the window. I thought these might be the antenna. Don't know for sure. I was told by a mechanic that if you are using old software, the GPS might lose where it's at due to all the new roads and such. Who knows for sure?
I've heard that it's under the rear shelf and that metal tint will screw them up. And they will get lost on new roads if they're not in the system. Mine has me driving in the woods on the new US-421 between Winston and Wilkesboro.
if anyone is interested if you have a NAV with antenna inside the car DO NOT put metalic Tint on your back window.. even high preformance tint. .I just riped of the high preformance tint and istalled regular tint and the navigation now works..
Originally posted by kingloose Paul you are absolutely correct.. lexus gave me acopy of the diagram where its located. it is in a back under the deck..
Do I have to remove the back seat in order to remove the GPS antenna? Would you also send me the diagram to knn444@yahoo.com? Thanks.
The antenna is under the rear deck next to mark levitson Subwoofer i belive its to the right of it.. you will see a black box. i dont have the diargrams any more.. sorry.
