instrument panel back light not dimming..
Old Mar 1, 2004 | 07:59 PM
Straight6's Avatar
Straight6
Default instrument panel back light not dimming..
the back light on the instrument panel on my GS is not dimming when
i turn the park or head lights on. what could be the problem? today's
the first time it happened. can anyone shed some light to this?
Old Mar 2, 2004 | 05:52 AM
Letsride's Avatar
Letsride
Are you doing this in the daytime?
Old Mar 2, 2004 | 06:37 AM
Straight6's Avatar
Straight6
i tried it both in daytime and nite. what could it be?
Old Mar 2, 2004 | 03:29 PM
rgarjr's Avatar
rgarjr
I could possibly that little adjusting **** thats gone bad or something.
Old Mar 2, 2004 | 03:49 PM
Threxx's Avatar
Threxx
I could be wrong but I think my instrument panel's backlighting is determined by a culmination of what the light sensors in the car perceive as far as ambient lighting goes, and where I have the little rotary **** to the left of my instrument cluster set to.
I don't think it really matters if my lights are on or off.
Old Mar 3, 2004 | 05:33 AM
Straight6's Avatar
Straight6
it's not the **** coz when i turn it.. it dims..
is there a fuse for the sensors?
Old Mar 3, 2004 | 08:54 AM
SeattleGS400's Avatar
SeattleGS400
That's my belief as well. During the daytime, the rotary switch won't do much to the brightness of the instrument gauges, as the light sensors are detecting "daytime" and it pretty much puts it at full brightness for full visibility (say 5/5) (of course, if you drive in a dark tunnel, it will switch to a lower brightness setting so it doesn't overwhelm you with too much brightness). The gauges need backlighting whether the car has it's headlights on or off, else they'll remain black and cna't be read!
During the night time, the gauges will automatically dim to a lower level upon car startup (say 3/5), and will adjust accordingly--if you want it lower, you'll have to dim it using the rotary ****. If it's really dark outside, your car will start up in maybe 2/5 brightness.
Old Mar 3, 2004 | 01:40 PM
Straight6's Avatar
Straight6
can anyone with a service manual check if the sensors have a fuse? or
or the possible culprit on this?
GSTank
Jan 23, 2012 08:23 AM
shikbas
Jan 16, 2006 08:58 AM
vert310
Oct 3, 2005 05:41 PM
oogster
Jan 13, 2004 04:30 PM
crazyfool
RX - 1st Gen (1999-2003)
Aug 29, 2002 11:56 AM
