Rockauto
Old Jan 7, 2026 | 11:14 AM
owel's Avatar
owel
Default Rockauto
Hi,
I ordered a Power Stop Rotor and Brake Pad kit (Front) from Rockauto. It includes two rotors and one brake pad. I would like to know if the brake pad is only for one rotor or two rotors. I assume it would be for two rotors but just want to make sure to minimize downtime.
I know it sounds weird asking this info on this forum, but I could not get answer from its Help section page nor getting it through telephone customer services which the company does not provide.
I would appreciate info from those who bought similar item from this vendor. Thanks
Old Jan 7, 2026 | 11:22 AM
Rock Auto is pretty good at providing pictures which show exactly what you are buying, in your case two rotors 4 brake pads, plus clips, grease and some rubber boots.
Old Jan 7, 2026 | 11:23 AM
chuyrobles's Avatar
chuyrobles
Depends on the item description. You will get a full brake kit for both sides, or one side. If one side, you add two to the order. It is possible you got an extra rotor.
Old Jan 7, 2026 | 11:29 AM
chuyrobles's Avatar
chuyrobles
Also, look at the pricing. In a kit the individual pricing of the parts will be about about 5-20 per cent more than the kit.
Old Jan 7, 2026 | 02:48 PM
owel's Avatar
owel
Chuyrobles, Tried that pricing logic but could not match the exact individual parts with the kit.
Lex2K, The picture shows two front views and two rear views. I initially though that will be four pads or good for two rotors. However, it could also mean that the rear view is being shown just to indicate the model # of that front pad which i just interpreted as two pads. Hence my clarification question.
Guys, thanks for your prompt response.
Old Jan 7, 2026 | 02:57 PM
Post the link to exactly what you bought.
Old Jan 7, 2026 | 09:37 PM
owel's Avatar
owel
https://www.rockauto.com/en/moreinfo...=13824&jsn=442
it is Power Stop Part # KOE 1077. Complete kit is 125.79 USD.
also ordered Power Stop Part # 17771 (17-771) for rear brake pad only . One set at 22.79 USD which i assume would be for both sides.
https://www.rockauto.com/en/moreinfo...t=1684&jsn=532
also, what youtube link is best to watch for rear pad replacement. Thanks again.
Last edited by owel; Jan 7, 2026 at 09:47 PM. Reason: clarity for kit vs part only.
Old Jan 8, 2026 | 05:54 AM
TrueGS300's Avatar
TrueGS300
Your order looks fine to me. You have a full set of front pads and rotors, and a full set of rear pads.
Old Jan 8, 2026 | 09:55 AM
owel's Avatar
owel
That removes one of my concerns. Thank you sir.
Old Jan 9, 2026 | 11:38 AM
chuyrobles's Avatar
chuyrobles
Looks like you are missing the brake pads. I don't think you can even buy pads for just one side. Here is the link to the kit on the Powerstop website: https://www.powerstop.com/search//?part=KOE1077
Old Jan 10, 2026 | 11:16 AM
owel's Avatar
owel
Chuyrobles, As I see it, the pix on your link has the same components as the Rockauto link. Anyway, Rockauto has shipped the order with ETA jan 15. Will post the items once I received it. Thanks for the input.
Old Jan 10, 2026 | 11:52 AM
I didn't know Power Stop had unpainted blanks.
Old Jan 15, 2026 | 02:06 PM
owel's Avatar
owel
front pads with rotor in the box
rear pads
rear pads
Items received from Rockauto. These are the complete set i need to do the brake jobs. Thanks guys for your inputs.
Feb 7, 2024 01:41 PM
lexus-is2
Nov 21, 2012 01:05 PM
endollan
Feb 13, 2011 04:34 PM
JohnEd
Feb 23, 2007 06:10 PM
