Panic Time
Old May 7, 2023 | 12:29 PM
BorderGuy's Avatar
BorderGuy
Angry Panic Time
I purchased a 2002 base GS last November. All has been well. Recently purchased a new battery. Today I insert the key in the ignition, the steering wheel goes to its programmed position, but I'm unable to rotate the key at all. The fob will unlock the doors, open the trunk and set off the panic alarm, so apparently the battery within in it is not dead. Does the fob not communicate if its battery is somewhat weak?
Any thoughts, suggestions?
Old May 7, 2023 | 02:35 PM
firelizard's Avatar
firelizard
Is your steering wheel locked?
If so, just turn it a little while you turn the key.
The immobilizer has nothing to do with being able to turn the key, it only prevents the car from starting without the chip present.
Old May 7, 2023 | 03:43 PM
BorderGuy's Avatar
BorderGuy
Just prior to your reply I gave it another (4th) try and it turned and started. This time, like previous times there were a few beeps to be heard. After reading your question, I checked the steering wheel and it was not locked, and this time no beeps and it turned to the start position immediately. I just love intermittents.
Old May 7, 2023 | 03:47 PM
BorderGuy's Avatar
BorderGuy
Maybe the beeps were trying to tell me the steering wheel was locked.
Old May 15, 2023 | 02:19 PM
dwoods801's Avatar
dwoods801
Once you were able to turn the key, you would have unlocked the steering wheel, and have no way to check it afterwards. If this ever happens again, try turning the wheel to the left then try the key and it should release the pressure that’s binding it up, and let u you start the car.
Old May 15, 2023 | 03:16 PM
BorderGuy's Avatar
BorderGuy
Thank you!
Old May 15, 2023 | 04:16 PM
Raven01750's Avatar
Raven01750
Yea. This is at the very least a Toyota Feature. I found that out back in 86 when I bought a brand new MR2. There a couple of times I thought I was going to break the key trying to get the switch to turn. And the dealer said that if I turn the wheel (and it's just a tiny tiny bit, it will unlock. Never had the issue again after.
Paul
Old May 19, 2023 | 03:55 PM
JaySco's Avatar
JaySco
It happened to me in my old Miata. Felt like a total moron . Now I know
Old May 19, 2023 | 04:36 PM
BorderGuy's Avatar
BorderGuy
Yes, happened to me frequently with my Miata, but this was the 1st time in the 6 months I've had this car that it happened. I do relate to the moron feeling.
Old May 19, 2023 | 09:26 PM
lexo98's Avatar
lexo98
Happened to me back in 2000. Was supposed to go show off my GS for new years and had it parked for a couple days. Damn steering wheel lock got me
cayloreese
Jan 28, 2018 05:09 PM
glex4
Oct 30, 2017 11:11 PM
jailechef
Sep 30, 2012 02:58 PM
njmurvin
Mar 10, 2010 09:42 AM
mir
Aug 31, 2007 03:20 PM
