Gas Cap Door Wont Open
Old Apr 6, 2023 | 04:06 AM
QLex300's Avatar
QLex300
Default Gas Cap Door Wont Open
Good morning,
Has anyone experience this issue?
I can hear my Gas cap clicking and will pop open but Im starting to experience the Gas cap door not opening .
Any advice or thoughts be Appreciated.
Thanks
Q
Old Apr 11, 2023 | 02:11 AM
dwoods801's Avatar
dwoods801
Are you referring to the gas cap? Or the gas door? The gas cap should click a few times when u fully tighten it. If your having trouble getting the gas cap off, then it’s probably just worn out and needs to be replaced.
If your referring to the gas door not opening then it could be the the cable has stretched over time? Or it could be the latch needs to be adjusted. If you are having trouble getting the gas door to open, you’ll find a manual release in the trunk, behind where the gas door is located, u can always use that to pop the door.
Old Apr 11, 2023 | 03:52 AM
QLex300's Avatar
QLex300
Thanks yes it clicks, but wont open.
I ordered a new spring to pop open the door to the gas cap.
Thanks
KarenAnne
Feb 26, 2023 11:01 PM
jettate
Mar 3, 2022 03:53 PM
Jan 7, 2022 07:34 AM
richard203
RX - 4th Gen (2016-2022)
12
May 28, 2019 12:04 PM
Boomin
Feb 10, 2014 05:34 AM
