differential questions
Old Jul 11, 2003 | 10:37 AM
minh's Avatar
minh
Default differential questions
My mechanic says that my differential is going out. Anyone know what my replacement options are? Any upgrades I can do at this time? Supra LSD? Thanks.
Minh
Old Jul 11, 2003 | 04:23 PM
Pianoman72's Avatar
Pianoman72
Is it making a whining noise when cruising especially when you let off the gas?
I want to say ron millen motorsports?? I've seen them online for the 1st gen gs, but wasn't paying much attention. Run a search in the sc300 forums, odds are if they have LSD for the 1st gen SC then they have one for the GS. I think that's how I came across the ones I found. I'd do some digging for you but I'm going home and I'll be away from the CPU this weekend.
Might was well do the upgrade, I'd say. Of course I haven't seen the prices yet. How much for a stock differential?
Sorry to hear about your car. That sucks. Sold my '72 cutlass for that reason (the last straw).
Old Jul 11, 2003 | 07:39 PM
minh's Avatar
minh
At low speeds (under 5mph) sounds like rocks or marbles ratting around. At higher speeds you don't hear anything except the occasional clunck (like loose suspension parts banging on each other) when hitting a bump of some sort.
Old Jul 14, 2003 | 10:08 AM
Pianoman72's Avatar
Pianoman72
Any luck yet? I did some digging for you.
The TRD part # for their LSD is the same for all ARISTOs and the Supra so I imagine other Supra applications will work. I saw some posts about the Supra TT LSD changing the final drive ratio and possibly affecting the accuracy of the speedo.
TRD's list. Ignore the bit about the "side gear shaft," that's only required for Japan-spec models.
http://www.toyota-trd.com./en/strt/d_lsd.html
If I were you I'd try to get the TRD one but I would also run some more searches and get some questions answered by some people who have done the upgrade.
Old Jul 14, 2003 | 11:47 AM
minh's Avatar
minh
Thanks pianoman, I'm gonna get a second opinion from another mechanic. If it is in fact the differential, I probabaly will spend the few extra bux and get the TRD LSD. Thanks again.
Minh
Old Jul 17, 2003 | 11:57 PM
2Lexos's Avatar
2Lexos
Chicago Lexus Club Moderator
hey minh, your best bet is to call Steve over at Carson Toyota or shoot him an PM here on CL at SUPRATRD........he'll take care of you.
Old Jul 18, 2003 | 12:07 AM
LB Lex's Avatar
LB Lex
If you need to replace the whole differential, think about changing the gears too. You can get a lower gear (higher number, e.g. 3.75 v. 4.10), which would really help standing-start acceleration, but it would reduce your overall mpg because your engine would be cruising at a higher rpm in 4th gear.
Just something to think about.
Old Jul 18, 2003 | 05:49 PM
minh's Avatar
minh
Thanks for the advice Eric. I'll keep it in mind. My car can definately use a little bit of help in the acceleration department.
Asap29
May 5, 2019 06:51 AM
k7q
Jan 14, 2014 03:58 PM
Epik
20
Dec 23, 2009 09:01 PM
LS400life
14
Nov 14, 2008 11:56 PM
XYZLexus1
May 4, 2004 04:09 PM
