Problem, car doesn't always start
Old Jun 26, 2003 | 04:10 PM
LB Lex's Avatar
LB Lex
Question Problem, car doesn't always start
My car has been giving me problems lately, especially when it is warm/hot outside. Sometimes my car just doesn't start. I turn the key and nothing happens, I don't hear any sound from the starter. The battery is new and the starter was changed a few months ago. I also changed the starter relay a while ago. If I turn the ignition a couple times, sometimes it starts, but sometimes (like today) it doesn't. After a half hour or so, I would go back and turn the key and it starts up right away.
I don't want to drive it anymore because I don't want to be stranded. Does anyone know what is causing this problem?
Old Jun 26, 2003 | 04:56 PM
link13's Avatar
link13
Default ignition switch
sounds like it might be a faulty ignition switch.
Old Jun 26, 2003 | 08:46 PM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Make sure the connection to the battery is tight. The connection to the battery can come off over time.
Old Jun 27, 2003 | 11:40 AM
LB Lex's Avatar
LB Lex
the battery cables are tight. Maybe it is a faulty ignition switch, but I'm not sure.
Any other suggestions I can try before bringing it to an automotive electronic shop?
Old Jun 28, 2003 | 02:06 AM
GSMan300's Avatar
GSMan300
Default I had the EXACT same problem.
Hey man,
I had the exact same problem with my 1994 GS300 a while back. I know what you are feeling man, it is real frustrating not knowing whether or not your car is going to start. When it doesn't start it feels like your heart has skipped a beat. It also seemed like it woud not start on hot days which I found to be weird also.
Anways, when I was in your shoes I tried everything such as:
-Changing alternator
-Changing battery
-Scrubbing battery terminals
-Checking connections
*It turns out that alternators purchased from Lexus seperately are all REFURBISHED and occasionally you get a faulty one even though they are suppose to work fine. That is why Lexus gives you a 1 year warranty on them. A bad alternator drains the average charge on your battery so what you need to do is:
1. Go to Lexus with your alternator receipt and get them to put in a new one.
2. Take your car to (I forgot the name) any battery and tire place and get them to recharge the battery. This might take a couple of hours.
Good Luck!
Old Jun 28, 2003 | 10:17 AM
LB Lex's Avatar
LB Lex
GSMan300- thanks for the info. So, you were having this problem before you changed your alternator to the Lexus refurbished unit? My alternator hasn't been changed and the battery is fully charged, so I don't think I would be suffering from a faulty alternator. My starter was changed a while back, do you think this was faulty?
Old Jun 30, 2003 | 01:05 AM
LB Lex's Avatar
LB Lex
Well, I had my car checked out. Starter, ignition, computer, starter relay, battery, and the alternator are A-OK. I'm starting to think that the transmission switch is going bad. If the car is in reverse or drive it won't start, and maybe my car thinks it is in gear, that's why it is giving no error codes and doesn't start. What do you guys think?
Old Jul 15, 2003 | 05:59 AM
RooLex's Avatar
RooLex
Talking
I had the very same problem
I pulled my car in to my workshop to do work on it and when I went to start it, nope !! it just didn't want to !!.
But some good news is that I found out what the problem was..... I had the same ideas as you guys at first but then I start the checking the sensor swich on the gear box. My GS is a 91so chances are my sensor go a lot more use
1st Try running your gear stick down and up the gears and back to park then try to start it.
If that doesn't work
2nd Try putting it in to " N " then try to start it
3rd Put in your key - turn it all the way while moving your gear stick up and down through " P " and " N "
If this is the problem then most of time my will start if I just move it in to " N ". But I all ran a new switch which by-passes the gear box sensors just incase.
Hope this helps.
Old Jul 15, 2003 | 04:29 PM
LB Lex's Avatar
LB Lex
Thanks for the responses guys! I had an auto-electrician look at the car and he discovered that the starter relay and starter were malfunctioning. Now its fixed and I no longer worry about my car leaving me stranded
Old Jul 16, 2003 | 09:05 PM
Wald GS's Avatar
Wald GS
That's good Eric. Glad you are back on the road again!!
Old Jul 17, 2003 | 12:12 AM
LB Lex's Avatar
LB Lex
It is pretty embarassing to call a cab to take my girl home because my car won't start
Hey, since none of us 1st Gen owners did went to the Carson meet, we should get together and have a mini-meet of our own. You guys are really cool and have some really nice rides. It would be nice for our little community to get together and meet each other in person.
jckol
Dec 8, 2016 08:34 AM
lexus1125
RX - 1st Gen (1999-2003)
Mar 25, 2008 12:10 PM
electro992
Jul 6, 2005 10:20 PM
99jewel
15
Jun 28, 2005 09:52 AM
UTGS400
Maintenance
May 12, 2005 06:58 AM
