Break light on????
Old Oct 17, 2012 | 10:01 PM
rjtillman's Avatar
rjtillman
Default Break light on????
I have noticed each time I hit my breaks he break light comes on. Has anyone ever had this problem.
Robert
Old Oct 18, 2012 | 12:08 PM
RAMPAGEsd's Avatar
RAMPAGEsd
check your bulbs on the tail lights. could be one of the filaments are burned out throwing the error.
Old Oct 18, 2012 | 12:35 PM
10thMtnLex's Avatar
10thMtnLex
Never had that problem with my lexus, but my old RA43 Celica would occasionally show a brake warning light for the simple reason of low brake fluid (small leak, or pads worn way down, lowering the level in the master cylinder). Quick and simple to check, and could be quick and cheap to fix. Let us know what you find...
Old Oct 18, 2012 | 04:58 PM
ayyofresh's Avatar
ayyofresh
I have the same problem. I replaced the bulbs it was good for a day then it came back on. Everything seemed to work fine. I would like to know as well.
Old Oct 18, 2012 | 07:02 PM
2GSC300's Avatar
2GSC300
Check brake fluid in master cylinder. Its probably low because your brake pads are low, which requires more fluid due to the piston being so far out. It brings the fluid level in the master cylinder below the sensor. Thats cause the light to come on
Old Oct 19, 2012 | 03:23 PM
onelt1's Avatar
onelt1
Yes check your brake fluid level. Same happened to me on my jetta thought it was the parking brake sticking, filled the brake fluid up and no more light
Old Oct 20, 2012 | 05:08 PM
Lextra's Avatar
Lextra
It's a brake fluid issue. My brake light would come on going up steep hills. I put a few spills of brake fluid and haven't seen the light sense.
Old Oct 22, 2012 | 11:45 AM
2GSC300's Avatar
2GSC300
Hope you guys know that when the brake fluid is low that means the pads are low too. When you replace them and push the piston in, it will over flow.
Old Oct 22, 2012 | 12:56 PM
onelt1's Avatar
onelt1
That's why you bleed your breaks after you replace the pads. You might want to check the condition of your rotors as well.
Old Nov 6, 2012 | 09:59 PM
rjtillman's Avatar
rjtillman
Hi All!
The verdict is in....you all were right. My brake fluid was low. And yes, I need new rotators and break pads. Thanks so much.
armanitran
Dec 30, 2014 09:15 PM
LexBubba55
Jan 18, 2012 09:49 AM
breakb
Maintenance
Feb 17, 2009 06:42 AM
jdmtruong
Nov 28, 2006 06:49 PM
SLVRGS
Nov 26, 2003 06:53 AM
