compression test results...
Old Feb 22, 2004 | 12:30 AM
indypwr's Avatar
indypwr
Default compression test results...
went to my mechanic today and got compression test. my car has 134000 miles, with no major problems. i was just curious as how my compression is holding up for each cylinder and here are
the results:
1st cylinder reading.......175
2nd cylinder reading......175
3rd cylinder reading........175
4th cylinder reading.........168
5th cylinder reading........175
6th cylinder reading....... 175
as you can see, nbr 4 cylinder is a little low and most likely due to some sticky valve but nothing major. sticky valve means that the valve might not be sitting right or as perfect as before or there cud be also some leakage on the seals. i wish i had taken a picture while the car was being tested and show you guys each reading from the meter that was being used. all in all, my car runs excellent and i can
go along with my na-t project h'ever, i will consider to re-prep my head and install metal head gasket for turbocharging.
for those of you guys who has reached at least the same mileage as mine, have a compression test
just to see how the internal parts are holding up before any mechanical problems you might encounter in the future which of course will costs you a lot of money.
now, let me gather my parts and start my project...............ppssssssssssssssssssssstttttt
Old Feb 22, 2004 | 02:11 PM
LB Lex's Avatar
LB Lex
What are the cylinder pressures supposed to be in a new car, and what are the pressures supposed to be in an engine with roughly the same amount of miles as yours?
Old Feb 22, 2004 | 08:21 PM
BLKCISCO's Avatar
BLKCISCO
Yo Indypwr, thanks for the info. i am right there with you at 131000. I will have to look into that, also check out some of our pic's we took at a car meet in south fl. Under a thread call turboTV meet in the GS300 section. nice turn out and we represent CL very well.
Old Feb 23, 2004 | 09:09 AM
indypwr's Avatar
indypwr
Post
ERIC: im not sure what the pressure supposed to be on our cars, i shud hv checked, huh?
but i guess as long as there are no signs of leakage in yr valves, you're ok. just keep up
the 3000 miles oil change in a regular basis and your engine will last fr a very long time.
Old Feb 24, 2004 | 12:29 AM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Mind I ask how much the test cost? thx
Old Feb 24, 2004 | 01:07 AM
indypwr's Avatar
indypwr
Wink
cost nothing to me....heheh......
my mechanic is pretty cool........but i gave him 40 bucks.......i felt kind of bad. took them 1 hr to do the work by taking out the throttle body, plug wires, etc...
silver470
Sep 12, 2015 07:19 PM
nitrotang
Aug 17, 2011 03:44 PM
SC300_704
Oct 9, 2008 05:08 PM
Scoupe3
Jul 17, 2007 01:47 PM
indypwr
Mar 2, 2004 11:02 PM
