tachometer and a/c back light replacement...
Old Jan 23, 2004 | 05:12 AM
95greengs's Avatar
95greengs
Default tachometer and a/c back light replacement...
My 95 GS300 has a couple of backlights not working. Can these be changed fairly easily or is it something a mechanic should do? If fairly easy where do you get the replacement lights?
Old Jan 23, 2004 | 08:48 AM
BigVIPness's Avatar
BigVIPness
The Green Grundel
I saw a post about doing this one time and I bookmarked it but I lost it. I would like to know too cause I want to swap out all the green LED's with ice blue.
Old Jan 23, 2004 | 08:55 AM
C to the O's Avatar
C to the O
I think O.L.T. is the person to talk to about this. I'm not sure if he's familiar w/ 1st gen gs's specifically, but I'm sure this is his area of expertise.
Old Jan 23, 2004 | 12:07 PM
BigVIPness's Avatar
BigVIPness
The Green Grundel
Found this:
https://www.clublexus.com/forums/sho...hlight=RED+LED
Old Jan 23, 2004 | 02:58 PM
BLKCISCO's Avatar
BLKCISCO
Hey 95green. its not that hard of a job. i had a few of mines go out and replaced them. I got my bulbs from the dealer they ran about $2 each i think, its been a while. DIY and save the money. I just got in and started taking out screws in the dash and pulled out the console disconnected the electrical plugs and swapped out the bulbs. If you just take your time doing it you will work your way through it with no problem.
Old Jan 24, 2004 | 12:52 PM
C to the O's Avatar
C to the O
BLKCISCO,
That sounds easy enough. How's about a walkthrough where and how many screws we need to take out? How long did it take you do do everything, start to finish?
Old Jan 24, 2004 | 01:25 PM
LB Lex's Avatar
LB Lex
From what I've read in the SC forum, the backlight bulbs are easy to replace. If your needles are not working, that's a different story because Lexus doesn't sell the needles or the bulbs separately...you have to spend hundreds of $$ on a new instrument console.
Old Apr 6, 2004 | 08:06 AM
1quikGS's Avatar
1quikGS
Has anyone used LEXTECH before?
Old Apr 6, 2004 | 12:54 PM
Mischievious GS's Avatar
Mischievious GS
Post
as soon as i find some time (or get off my lazy a*), i'm going to send mines in
Old Apr 7, 2004 | 03:34 PM
Vegassc400's Avatar
Vegassc400
Lextech is great. Easy to work with and very quick. The SC peoples are very happy.
winter4w
Mar 23, 2015 06:50 AM
frotiss
Nov 13, 2012 01:50 PM
tommyjaix
Lighting
Jul 18, 2007 08:12 PM
Brian_B
May 13, 2006 02:37 PM
