CA New Accuair e-Level Air Management Stage 2 Package
Bought this a few months ago same time as a couple of known members on here Brociouz and Hoovey. Unfortunately had to put the car back to stock and never got a chance to finish the install
This is the COMPLETE air manangement kit less the bags.
Stage 2 kit includes:
(1) e-Level Controller w/ TouchPad Interface
(1) Electronic Control Unit (ECU)
(1) TouchPad TM Interface ( Black Anodized)
(4) Ride Height Sensors w/ Linkage
(1) 4-Corner Height Sensor Harness (20/20/16/16 ft)
(1) 4-Corner Solenoid Valve Harness (1 ft Pigtail)
(1) Main Power Harness w/ Built-in Fuses
(1) 0-200 psi Tank Pressure Sensor
(1) Stainless Steel Mounting Hardware
(1) VU4 4-Corner Valve Unit
(1) VU4 4-Corner Solenoid Valve Unit
(1) 1 ft Plug-n-Play Weatherproof Harness (for use with e-Level or SwitchSpeed controllers). Splice for use with any other controller or switches.
(1) 3/8" Plastic Spare-Inlet Plug
(1) Stainless Steel Mounting Hardware Package
(2) 400C compressor with standard rubber mounting feet
(1) 18" stainless steel leader hose with built in check valve
(1) Screw in air filter with optional remote mounting hardware
(1) 40 Amp Viair relay
(1) 5-Gallon Black Anodized Aluminum Air Tank
(1) Serviceable Black Aluminum Air Filter/Trap
(1) 3/8" D.O.T. Approved Plumbing Kit
(50 ft) 3/8" D.O.T. approved plastic airline
(4) 90° 3/8" P.T.C./D.O.T. swivel-elbow to 3/8" or 1/4" NPT fittings for Air Springs
(1) Straight 3/8" P.T.C./D.O.T. to 3/8" NPT fitting for tank
(6 ml) tube of Loctite 565 Thread Sealant
(1) Installation & Operation Manuals
In addition I got the following extras/options with the kit:
Black anodize tank $75 extra
EXO2 mount dual compressor $250
Power supply Kit $125
Key-Fob remote system $195
I started to put the EXO mount and the tank together and built a custom box for it just to see how nice it looked on the trunk but thats only how far i got
There's over $2800 in stuff here before tax and shipping
Asking $xxxx for everything
