Triple Beam Headlight Mositure
Old Jan 14, 2026 | 07:56 AM
mikemu30's Avatar
mikemu30
Default Triple Beam Headlight Mositure
Passenger side headlamp collecting moisture - light is still functioning (for now). Anyone successfully dry it out and reseal?
Old Jan 14, 2026 | 09:53 AM
E46CT's Avatar
E46CT
how bad is it. pics? just one light or both?
ive done several headlight reseals, retrofits, etc. its a bit of a chore, but not that hard. could you just get a used headlight?
Old Jan 14, 2026 | 09:55 AM
ESh's Avatar
ESh
I don't know exactly which model of the headlights you have but for some models you can purchase the glass and the seal and replace them.
Old Jan 14, 2026 | 10:00 AM
E46CT's Avatar
E46CT
he has triple beam i believe. mike doesn't like them much.
Old Jan 14, 2026 | 10:30 AM
mikemu30's Avatar
mikemu30
Yeah triple beams passenger side only. Appears to be a fairly common issue sadly.
Old Jan 15, 2026 | 06:16 AM
LeksioReksio's Avatar
LeksioReksio
G'Day. Is it wrong to assume that without signs of impact this problem should be covered by Lexus Bumper to bumper warranty?
Old Jan 15, 2026 | 07:23 AM
mikemu30's Avatar
mikemu30
My ES is SEVEN years old with nearly 90Kmiles
Old Jan 15, 2026 | 07:55 AM
E46CT's Avatar
E46CT
Live with it. I'm guessing the moisture isnt that noticeable and just aesthetics.
But if it bugs you, replace used from ebay.
if the cost is too high, and you're brave, attempt a fix. but i doubt you'll want to waste your time with that. i'm guessing replacing requires removal of the front bumper. its about 1k for used one without damage
Old Jan 15, 2026 | 08:10 AM
ESh's Avatar
ESh
If it is made in Japan then you can get the glass and the seal.
Old Jan 15, 2026 | 01:26 PM
mikemu30's Avatar
mikemu30
Pretty sure my ES was built in Kentucky.
Old Jan 16, 2026 | 05:10 AM
ESh's Avatar
ESh
If 2019 there’s a big chance that was made in Japan.
Old Jan 16, 2026 | 05:29 AM
mikemu30's Avatar
mikemu30
I don't mind living with it it at all - just worried about the electronics.
Old Jan 16, 2026 | 07:27 AM
E46CT's Avatar
E46CT
i think you'll be fine. i mean if you wait til the electronics blow which is just a controller module which itself should be sealed, then you'd simply have delayed the replacement cost and it'll be cheaper then -- vs replacing it now.
Old Jan 16, 2026 | 07:47 AM
mikemu30's Avatar
mikemu30
I am thrilled to hear that. I will let it be! Thx for the info.
Old Jan 16, 2026 | 02:12 PM
pab12's Avatar
pab12
Did anyone reflect on the fact that the triple beam headlamps are >$2000 each?
