Triple Beam Headlight Mositure
Old Jan 16, 2026 | 02:47 PM
alextv's Avatar
alextv
Originally Posted by pab12
Did anyone reflect on the fact that the triple beam headlamps are >$2000 each?
When body shop replaced 1 triple light the part alone was $3500.
Old Jan 16, 2026 | 03:01 PM
mikemu30's Avatar
mikemu30
It's a reason I tried to find my ES without them. I failed at that but did get it sans AVS, another potential expensive replacement.
Old Jan 17, 2026 | 09:22 AM
bc6152's Avatar
bc6152
After reading your post Mike, I went onto Utube and found that there should be a vent on the assembly. The video showed the person using a hair dryer at the vent opening and all of the condensation went away. This wasn't a Lexus ES. Now I don't know, and haven't looked, (its snowing outside) at ours but maybe this would apply to our ES 350's. You're probably getting the snow across the river too. Supposed to be nicer tomorrow... GOOD LUCK!
Old Jan 17, 2026 | 10:11 AM
mikemu30's Avatar
mikemu30
Many thanks. I will check it out when the snow lets up here in NJ. A surprise 4" blast today.
Old Jan 18, 2026 | 04:18 PM
sderman's Avatar
sderman
Might be worth hooking up a battery tender and leaving the headlights on for a few hours (assuming the car is garaged and the lights don't time out). LED's put out some heat and that might drive out the moisture.
Old Jan 19, 2026 | 05:18 PM
peterbuoy's Avatar
peterbuoy
6th Gear
Hi Mike, there were at least 7 people on one of the 7th gen ES facebook groups (including me) that have experienced triple beam condensation. Funnily enough the passenger side on my 2019 also just got condensation November 2025 and I was somehow able to get Lexus corporate to entirely cover it under good will -- maybe it helped that I had L/Certified and had a good sob story (my first Lexus... etc lol).
Anyway, the condensation will eventually kill your headlight entirely if left unchecked. The rate depends on the frequency and severity of the condensation. Your daytime running lights will probably die and after a while your headlamp may fail entirely. I've personally only seen one person state that their headlamp failed, but I think they lived in a harsh environment and they let it go on for nearly a year or something.
I would not advise buying used because there's a chance they are also cracked. Others have run into that exact issue... Also I'm pretty sure Lexus does not sell individual components for the triple beams and only sells the entire assembly. Dealer will charge you $3500 per headlight, but Bell lexus will charge you $2500.
Fun fact: the 2022-2025 triple beams are only $1600 at Bell Lexus. I do not know if they are plug and play with our 2019 though.
That's a lot of money, so realistically I think for most of us the fix is to either
  1. Aftermarket triple beams (2 people on the FB groups have successfully done it and they haven't complained in the past 5 months)
    1. I personally would not go this route because I don't trust it
  2. Reseal
    1. If the lens seal fails and you can do a cheap fix by finding the failing section and just going over it silicone caulk after drying it out.
    2. If you want, you can remove the entire lens and then just reseal it
    3. If there's a crack in the lens, there's some sort of adhesive/epoxy to fix it -- not really familiar with this.
Realistically, any car lighting professional should have the know how and tools to fix your problem. The headlights aren't magic.
Old Jan 20, 2026 | 05:35 AM
mikemu30's Avatar
mikemu30
  2. Reseal
Thx. I will attempt to find a shop that has dealt with this before. Appreciate the detailed response!
Old Jan 20, 2026 | 10:11 AM
asadani's Avatar
asadani
I had an accident and both of the triple beam lights were replaced for about 48,000 AED which is about 13,000 USD. Insane overcharge
rogerogden
HS 250h Model (2010-2012)
Jan 2, 2025 12:58 PM
Supersizeal
GX - 2nd Gen (2010-2023)
Sep 23, 2024 08:46 AM
Rjngo
Jul 6, 2024 09:05 AM
gearheader
CT 200h Model (2011-2017)
Jun 19, 2018 12:50 PM
TAP4636
May 13, 2009 09:25 AM
