Drive modes ... custom does not survive a driving session
I think "The Book" makes it clear that the "mode" is reset after the engine is turned off.
I would think that changing the color of the speedometer would be enough of a reminder for most drivers of the selected mode.
■ Automatic deactivation of sport mode and custom mode (if equipped)
If the engine switch is turned off after driving in sport mode or custom mode, the drive mode will be changed to normal mode.
Drive Mode "Sport" increased the fun but decreases the MPG results.
EPA/CAFE testing requires the test to be run in whatever mode the test vehicle starts up in.
Manufacturers do Not want to post the MPG results from a Sport Mode test cycle.
Thus: no default Sport Mode or Custom Mode w/ Sport throttle settings available at start up.
That's only on F Sport models equipped with the Adaptive Variable Suspension system. (See the "Vehicles with Adaptive Variable Suspension system" subsection under the "Driving Mode Select switch" section of the "4-5. Using the driving support systems" subchapter of any version of the (US and Canadian) Owner's Manual.)
For 2019 through 2022 model years, that is F Sport models equipped with the F SPORT DYNAMIC HANDLING PACKAGE. For 2023 and later model years, that is F Sport Handling models (where Adaptive Variable Suspension is a standard feature).
