Drive Mode Customization
Old Sep 3, 2022 | 12:06 PM
SunCruzin's Avatar
SunCruzin
Default Drive Mode Customization
Hi All. Can someone who has experience and/or knowledge please explain about the Drive Mode Customization in the vehicle system settings menu in the centre display.
If one changes the powertrain setting from normal to power, and chassis setting from normal to sport and then puts the drive mode into Sport Plus, will this make any enhancements to the performance or handling?
I recognize there is a Custom drive mode as well that can be programmed, but am uncertain if the Drive Mode Customization in the system settings menu only apply to Custom mode and not other drive modes as well.
Thank you in advance.
Old Sep 3, 2022 | 12:56 PM
SunCruzin's Avatar
SunCruzin
I possibly partially have answered my own question, except the part about what happens when the powertrain setting is changed to power from normal
Old Sep 3, 2022 | 01:30 PM
mcomer's Avatar
mcomer
Drive Mode affects the throttle response mapping except at Wide Open Throttle.
If you tip into the throttle 2" in Normal you will get a bit of power, same 2" will jump when in Power.
Drive Mode ECO is the opposite, 2" of throttle will be more leisurely acceleration. What is nice about
the Customization menu is when you want the throttle response to be lively (dynamic cruise control
will respond much closer to my actual drive style) but you want the plusher ride of normal or comfort.
Our ES 300h doesn't have the ability to customize the Drive Mode so it all or nothing in Sport.
Old Sep 3, 2022 | 02:49 PM
SunCruzin's Avatar
SunCruzin
That is interesting. Today, I changed the setting in the Drive Mode Customization, under the powertrain heading from normal to power and I felt like the engine was more responsive in Sport Plus mode, especially from a standstill and paddle shifting. Could I have been imagining this?
According to the chart, if I am reading it properly, just placing the car in Sport Plus should have the same effect as what I did inside the vehicle system settings using the track pad.
Or are the changes I made even applied to the car if I am not in Custom mode? A little confusing.
Old Sep 3, 2022 | 03:38 PM
74Sprtstr's Avatar
74Sprtstr
ever notice how all settings amount to Sport + detuned ?
no wonder, as i have recently discovered and maintained, that it runs BEST in Sport + ....
because thats the default setting ! ( duh on me too for taking so long to get this )
Old Sep 3, 2022 | 04:01 PM
SunCruzin's Avatar
SunCruzin
You are right, all the other settings appear to be detuned versions of the LC
Old Sep 4, 2022 | 04:16 AM
MLMLC52K18's Avatar
MLMLC52K18
100...Sport+ is the only way to go!
Old Sep 4, 2022 | 09:10 AM
74Sprtstr's Avatar
74Sprtstr
just like with a lotta things in life .... its full on all the way, with adjustments as needed ...
Old Sep 4, 2022 | 09:46 AM
SunCruzin's Avatar
SunCruzin
I hope I am not being daft, but I am still wondering though what is the effect of going into the vehicle system settings menu, using the track pad in the centre console, and changing the powertrain settings in Drive Mode Customization to "Power" from "Normal"
If I understand properly, (and I might not be), it will increase the throttle responsiveness. But does increased responsiveness only happen if I am using "Custom" drive mode or as well if I am in "Sport Plus" drive mode?
I might review the tutorial again about the 2022 from Northside to see if I can pick up any clarity.
Old Sep 4, 2022 | 03:12 PM
for fun sure, but not always, imo. sport+ only uses 8 of the 10 gears, so if one is taking a highway trip, sport+ is not ideal. i'd rather be in comfort with all 10 gears (plus smoother ride).
Old Sep 4, 2022 | 03:42 PM
MLMLC52K18's Avatar
MLMLC52K18
Bit...You are absolutely correct. There are alot of downsides to consider when driving in Sport+ mode. I never take my LC on trips. And I only primarily drive it locally. So on those rare occasions, I like the feel of the hold on lower gearing and the way the car responds to the pedal. I am certain that I am wasting a lil gas, but I don't care because I am in 'Zoom Zoooom' mode!
Old Sep 4, 2022 | 09:14 PM
agreed. i like zoom zoom sport+ on fun roads also.
Old Sep 5, 2022 | 01:20 PM
RCFun's Avatar
RCFun
Default Am I Missing something?
Sorry for the dumb question, but when I go into Drive Mode Customizations, I only have 3 things to choose from: Powertrain, Chassis, and Climate...I don't have the steering, or dynamic handling. Is this a regional difference? I'd love to have the heavier steering at all times, not just Sport+
Old Sep 5, 2022 | 01:32 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Powertrain = Powertrain
Chassis = AVS, EPS, LDH
Climate = AirConditioning
I have mine set up for Powertrain = Normal, Chassis = Sport, Climate = Normal
Old Sep 5, 2022 | 04:11 PM
SunCruzin's Avatar
SunCruzin
The attachment that MCOMER provided in one of the above posts, explains a lot. I have had my questions answered.
