Passenger side mirror damaged
Old Apr 1, 2022 | 03:45 PM
Shikhagill's Avatar
Shikhagill
Default Do i need a full mirror assembly?
Originally Posted by E46CT
I've taken these mirrors apart about 10 times so far? So they're really easy to disassemble. If I'm not mistaken you can fix this standing outside the car. Remove the glass (just pull from bottom with fingers, it clips in. Then there's philips screws on the inside that hold the outer halves together. total 3 pieces. Just ask the dealer if they sell the painted outer half, the top piece, and the inner piece. If so, you can fit them all to the inner core/frame and call it a day.
If you can only get the entire assembly, it will be expensive unless you go ebay. and even then it's expensive but you do need it. in that case, you'll need to remove the door panel to access the 3 bolts/nuts holding it to the door. but that's easy too. i made a thread on removing the door panel. and yeah you'll need the glass too of course. i think there's BSM and non BSM. IIRC all are heated. then i believe some mirror housings have the camera cutout. not sure which options your car has but you'll need to match them all.
My Rx 350 right door has similar kind of damage. How do we decide if full assembly is needed or outer cover will suffice. Everything is working. I do not see any internal damage. I do not understand why people are saying full assembly is needed?
my original is with BSM. Can i replace the mirror in my original with the non BSM assembly. Sorry if it is a stupid question but if everything is intact and working just the outer piece that supports is damaged why do I need to buy the whole assembly. Nobody has explained it to me. Can someone please provide me some insight.
thanks.
Old Apr 1, 2022 | 03:53 PM
E46CT's Avatar
E46CT
maybe cause they don't sell the parts separately? hard to say as you have an RX350 and you posted this in the ES section. the mirrors are different. you might want to ask your local dealer.
kbarbaro
Dec 31, 2021 07:28 AM
nanotech
Oct 7, 2021 02:35 PM
Yyzpvg
IS C
May 30, 2016 12:22 PM
nofish
Aug 30, 2011 08:31 AM
HKSC430
Jun 15, 2010 11:45 AM
