Using Android Phone WITHOUT Android Auto (2019 ES 350)
Old Sep 13, 2019 | 01:06 AM
2019ES350's Avatar
2019ES350
Question Using Android Phone WITHOUT Android Auto (2019 ES 350)
Android Auto is not available on the 2019 ES 350. How can I use my Android phone with that model?
I understand Android Auto will be available on the 2020 ES 350. Will a software update make it available in the future on the 2019 ES 350?
Any insight you can offer will be greatly appreciated! Thanks in advance.
Old Sep 13, 2019 | 07:53 AM
DavidZ's Avatar
DavidZ
Same as any car with Bluetooth.
I've only heard speculation about it. Nothing official. Do you have anything authoritative you can cite?
We can only speculate.
You're welcome!
Old Sep 14, 2019 | 12:05 AM
2019ES350's Avatar
2019ES350
Default Thanks, but what am I missing out on?
As an Android phone user, if my car is not compatible with Android Auto, what am I missing out on? I'm trying to determine whether it is a significant loss not to have Android Auto. Can anyone help me? Thanks!
Old Sep 14, 2019 | 05:20 AM
ALarsh's Avatar
ALarsh
This is Android auto. This is what your car will not have if you don't have Android auto.
https://www.android.com/auto/
Old Sep 14, 2019 | 06:26 AM
TechNut's Avatar
TechNut
Veteran: Navy
I can’t speak directly to Android Auto, but I use the Apple ecosystem and have been somewhat underwhelmed by Apple CarPlay. Frankly, I don’t see myself using it much, so based on that assessment, I don’t think you would be missing all that much.
First of all, the Toyota/Lexus systems have to be connected via a USB cable which isn’t terribly convenient. Second, what does it really do beyond mirror the phone’s screen onto the car display. This seems really targeted towards Waze users so if you live in a busy metropolitan area this may indeed have greater benefit to you. For me, the factory nav is good enough for my needs so this is truly a solution in search of a problem. So what else will CarPlay bring me? Music? I have that covered with car infotainment system already and I have no issues using it (once getting past the learning curve). Ok, then you have the ability to make phone calls using CarPlay - a service already covered via Bluetooth using the car’s native systems. It is just my humble opinion that using the vehicle’s native infotainment system and learning the voice prompts are nearly as effective as CarPlay without the need to always have the cable dangling and the need to plug in each time I get in the car.
Now considering those thoughts above, some people are virtually married to their phones and cannot even sit down in a restaurant without picking up their phone. If that fits you, then AA may have more value for you.
Old Sep 14, 2019 | 08:37 AM
CarToys's Avatar
CarToys
Probably the biggest benefit is being able to use google maps navigation using the car’s built-in infotainment system display and controls. This is especially important if your vehicle isn’t equipped with the factory navigation package (and even if it is equipped with it, a lot of people feel that google maps’ navigation is superior to Lexus/Toyota’s factory navigation system and would rather use google maps instead).
Old Sep 14, 2019 | 08:51 AM
DavidZ's Avatar
DavidZ
Originally Posted by CarToys
Probably the biggest benefit is being able to use google maps navigation...
I agree. And the biggest downsides are:
1) You have to plug it in every time you want to use it, and
2) It disables your USB stick. You can't use CarPlay and listen to music on a USB stick at the same time.
It will be interesting to see how Android Auto is deployed in the 2020 RX. My guess is that it will have the above 2 limitations, which are unnecessary design choices.
Old Sep 14, 2019 | 11:18 AM
coolsaber's Avatar
coolsaber
You are loosing out on the feature of having a phone integrated into the headunit basically.
Take a gander at the videos available on youtube, and see if this a feature which is crucial to you. I personally would not buy a vehicle without in 2019, as even entry level rental specials have this feature enabled, but again thats upto personal preference.
Old Sep 14, 2019 | 03:46 PM
LexRuger's Avatar
LexRuger
I'm an Android user but I decided to buy a second phone (iPhone) with a data plan just to use Google Maps. I keep it plugged on all the time unless I need to add music. Google Maps is more useful and up to date than the built in nav.
Old Sep 15, 2019 | 03:22 AM
DavidZ's Avatar
DavidZ
Do you leave the phone on all the time and let the car charge it back up? Or do you turn the phone off when you exit the car?
Also, how is this arrangement working out for you?
Old Sep 15, 2019 | 09:09 AM
LexRuger's Avatar
LexRuger
I leave the phone on and plugged in all the time.
It's working out fine for me but the only bad thing is when carplay is active, the cars' Bluetooth is disabled. So I can't use my Android phone hands free. But good thing I have my Galaxy Watch to answer and make calls on my Android phone.
If Lexus puts out an update to make my car Android Auto compatible, I'd get rid of the iPhone in a heartbeat.
Old Sep 15, 2019 | 09:57 AM
2019ES350's Avatar
2019ES350
I was able to speak with a knowledgeable person at Lexus headquarters about the "coming of Android Auto" to ES and a number of other Lexus cars. Unfortunately, a hardware limitation (not software) will make it impossible to add Android Auto to 2019 and older Lexus cars. A replacement of the "head" would cost several thousand dollars, and that is what would be needed. So, it sounds like you'll be keeping that iPhone for a while.
Old Sep 15, 2019 | 10:46 AM
DavidZ's Avatar
DavidZ
Thanks for the info.
If that's the case, then they need to get their asses in gear to fix the lame Navigation system, which is clearly a software issue. Then we won't need to use our iPhones for Google Maps or Waze.
I got much better results from my 2004 ES DVD-based Navigation than I do using this one.
Old Sep 15, 2019 | 02:04 PM
DaRacerz's Avatar
DaRacerz
I would take that with a bit of suspicion. For FWIW, Lexus Spain has an announcement on their site stating Android Auto upgrade for MY'19 ES built after October 2018. December 2019 update available for non-nav vehicles and April 2020 for nav vehicles.
https://www.lexusauto.es/ownership/a...d-auto/#recall
Staying hopeful there may be a retro-fit software update to look forward to.
Old Sep 15, 2019 | 03:23 PM
2019ES350's Avatar
2019ES350
Unhappy
DavidZ--
I'm disappointed to read your comment about the Lexus navigation system. Would you give us an idea of what the problems are. I use Waze and Google Maps all the time and would hate to make a move backward in changing to the navigation system in the 2019 ES 350 I am contemplating buying.
Thanks in advance.
