Dashcam suggestions, please.
Old Dec 30, 2019 | 05:58 PM
  #46
actionzhe's Avatar
actionzhe
Originally Posted by carsareus
The rear tint and power shade are all things I never considered. I think I may also go this same route. Let us know how things are going after you get this installed.
Will be happy to share my experience with it, just got the email from seller asking for picture of the mirror area. I chose expedited shipping, since they have $8 off coupon right now, it basically covered it. I should have it sometime next week.
Old Dec 30, 2019 | 08:46 PM
  #47
burnik's Avatar
burnik
I will be getting mine next week. Will be posting some shots as well.
Old Jan 10, 2020 | 09:44 AM
  #48
actionzhe's Avatar
actionzhe
Originally Posted by BobES2019
I installed the Fitcam just now. It is a very easy installation. The photo below shows the Fitcam module and the OEM module. First you slide off the OEM module. Then you connect the included "Y" cable. It reconnects the mirror sensor and feeds 12v to the camera. Then you slide on the camera module. It all simply plugs in and the wires are contained in the Fitcam module. There is a very minor texture between the Fitcam module and the the OEM module. Once installed, you cannot see any difference. I rate the Fitcam as looking like it is OEM. It does not look added on. This makes me a happy camper.
If you get this dash cam, pay attention to how the OEM module comes off. The Fitcam goes on the same way. You need to transfer the orange clips from the OEM to the Fitcam. Then take the blue lens protector off the Fitcam. Sounds obvious, but I initially missed it. You need no tools except the plastic removal tool included in the kit.
In about a week I will post how well the camera works and how clear the video is. I will include photos to show.
Hey Bob, I just got received my camera, did you use the plastic removal tool to remove the top arc of the mirror, or just used hand?
From the video on the product page the guy got it down by hand. I tried pulling out on it a bit and it didn't budge, but I also don't see any obvious points to insert the plastic removal tool...Not sure if I just need to pull on it harder or i need to pry it in some way
Edit: NVM figured it out, pulled with two hands from the top at the same time did the trick. Was too afraid to break it initially...
Old Jan 10, 2020 | 01:06 PM
  #49
BobES2019's Avatar
BobES2019
Well, I fiddled with the plastic removal tool and also could not find an obvious insertion point. I mostly pulled down hard with my hands on the small rear piece of the mirror housing ("top arc of mirror") and it suddenly just snapped off with no damage to anything. The replacement pieces go back on easily. Please use your best judgement.
Just saw your edit. Glad it worked.
Last edited by BobES2019; Jan 10, 2020 at 01:08 PM. Reason: Previous person edited his post
Old Jan 10, 2020 | 02:25 PM
  #50
actionzhe's Avatar
actionzhe
So I just got my dashcam installed this afternoon, and job took me about 1 hour because I was trying to be careful. The toughest part was getting the camera housing back on, since space was limited behind the plastic cover to begin with, trying to tuck the wires in properly and snap the cover on took me a bit.
The dashcam was shipped to me very well packaged, literally every inch of the shipping box was taped over. The box says it's designed for dealerships (4S shops), so it's probably one of the dealership gifts you can choose with a new car purchase, or sold as dealer accessory. The product box itself also contained plenty of protection, and does not feel cheap. And as expected we are paying a premium overseas, I found their Chinese product page on JD and they are selling it for ~$77 in China and it comes with installation. They literally have the product for every popular car model out there and got plenty of reviews.. that gave me a lot more confidence in that they are not some no name brand.
The installation in general is a lot more brute force than I expected, I was pretty scared at first since it was all hard plastic and I don't want to break something. But it's really just a lot of yanking and hard pulling and things will come off. I did not use the plastic trim removal tool at all, the key apparently is to just use two hands and always apply pressure evenly. The cables are designed very well and are foam protected. I did not understand why they had foams around the connectors until I tried to get the cover back on. It is TIGHT, and things will be squeezed against each other, that foam is definitely helpful. Tip here is to forget about tucking the wires until the main cover is back on. I tried for a long time to keep the wires neat while sliding the cover on, that did not work out very well.
It does look very OEM, and you easily forget that it's there. It's not that visible from the outside as well. There is a blue LED light that always flashes when it's recording, there is no way to turn it off in settings as far as I can tell. But it is hidden behind the mirror when I'm driving so all is well. The app is very easy to setup and use, just remember to turn off auto reconnect in your phone's wifi settings. I did not use the sandisk microsd that was included, because I noticed it was just a normal class 10 microSD. Instead I spent 10 bucks and purchased a Samsung pro endurance microSD that is designed for dashcam/bodycam use, and is meant to survive constant writes. After I took my short drive and realized how hot the microSD card gets, I think it was definitely a good call.
The camera stays recording for about a minute or two after car is shut off, basically the time for ACC to lose power. I turned parking mode off, although on their Chinese product page it does say parking mode is only for fuse box/OBD install anyways because those have constant power. I don't have any driving footage ready to share, I will post some next week. But I am happy to report that there is no gap or lags between each video files when it saves, and the video is pretty stable. But at 1080p, the resolution is really on the low side as expected, more to come on this when I get some driving footage in in different lighting conditions...
Anyways some pictures...
All the accessory in the box, wires, OBD connector if you choose to power it that way, trim removal tool, Sandisk microSD and a microSD USB reader.
How crowded it is back there after all the wires are in.
After snapping the cover back on, I couldn't tuck that last piece in quite right...oh well at least it's not visible from both driver and passenger side when mirror is in normal driving position
How the camera looks from outside
Old Jan 10, 2020 | 03:37 PM
  #51
BobES2019's Avatar
BobES2019
Actionzhe,
I am glad that you got your Fitcam installed. I believe you will be pleased with it. Do you know what the orange USB thumb drive is used for? I can download the recorded movies from the Fitcam wi-fi, or take the mini-SD card out and download the entire card to my computer.
The little blue light that blinks is fine. But at night it is visible on the passenger's lap. Although it is dim, it still bugged me. I put a small square of 3M black electrical tape over it.
Finally, despite being 1080p and not 4K, I believe the resolution is plenty adequate.
Old Jan 10, 2020 | 03:48 PM
  #52
actionzhe's Avatar
actionzhe
Actionzhe,
You mean the one in my picture that says MicroSD USB 2.0 on it? It's just a microSD to USB adapter, you insert the microSD into the slot on the end and plug it into your computer. It's for people without a SD card reader on their machine. It's only USB 2.0 so it's a bit slow, but I don't use it anyway since I got a microSD to SD adapter and that works much faster.
I haven't drove it at night yet to see how annoying the light is, but it's helpful when you paused the recording because you wanted to access something via the phone and forgot to restart it. The solid blue and blinking blue is a helpful indicator to see if it's actually recording.
Old Jan 10, 2020 | 06:18 PM
  #53
carsareus's Avatar
carsareus
I just took delivery of my 2020 ES350 UL yesterday and I've been following this thread. I'm very interested in purchasing this camera. I really want to try and maintain the OEM look if possible. Can someone address how long it took to receive this item once they placed the order? Also I can't find anyplace on the Amazon website that addresses how long the warranty is for this item. Thanks for sharing this information.
Old Jan 10, 2020 | 06:58 PM
  #54
actionzhe's Avatar
actionzhe
Took me 8 days with expedited shipping, but also had new year in between so it's probably 7 days normally. Assuming you reply to their email requesting a picture of the mirror area immediately.
There is warranty card inside the box, warranty is 1 year parts&labor, 2 year labor only. But I probably won't bother unless you want to ship it back to China...dashcam aren't really known to fail anyway so I'm not too worried.
Old Jan 11, 2020 | 07:28 AM
  #55
dklanecky1's Avatar
dklanecky1
Took me 8 days with expedited shipping, but also had new year in between so it's probably 7 days normally. Assuming you reply to their email requesting a picture of the mirror area immediately. There is warranty card inside the box, warranty is 1 year parts&labor, 2 year labor only. But I probably won't bother unless you want to ship it back to China...dashcam aren't really known to fail anyway so I'm not too worried.
Nice write up. Are you able to reformat the memory card from the app, or do you have access to it without removing everything, and basically re-installing? Most DashCams I've seen suggest reformatting the memory card at least monthly for best performance.
Old Jan 11, 2020 | 08:28 AM
  #56
actionzhe's Avatar
actionzhe
Yes you are able to reformat the memory card from the app. And it does mention on the box to check video footage and reformat the card every 1-2 months.
But the microSD card is also easily accessible, it's just a slot on the passenger side. Pulling footage by removing the card and plug into your computer and formatting is probably faster than wifi.
Old Jan 12, 2020 | 08:05 PM
  #57
clqw's Avatar
clqw
I also just ordered the FitCam dashcam, but i ordered it from its manufacturer's store- it's doing a Chinese new years special for like 1/2 the price on Amazon. We'll see how it turns out.
Old Jan 12, 2020 | 08:22 PM
  #58
2019ES350's Avatar
2019ES350
Would you post the URL of the manufacturer's store? Thanks in advance.
Old Jan 12, 2020 | 08:51 PM
  #59
clqw's Avatar
clqw
Not sure if you can understand Chinese lol but PM me if you can and want the link - dont want to advertise for them.
Old Jan 13, 2020 | 06:38 AM
  #60
Angelix's Avatar
Angelix
Could you please also share me the link thanks!
BTW I can understand Chinese.
