Parking Brake Malfunction
Old Nov 2, 2023 | 03:01 PM
Weaboo99's Avatar
Weaboo99
7th Gear
Default Parking Brake Malfunction
Outta the blue I get this message, planning on taking it to the dealer but wanted to know if anyone had any prior experience.
Old Nov 3, 2023 | 07:52 AM
july1988's Avatar
july1988
You bet, this is a quite common issue actually:
https://www.clublexus.com/forums/es-...ke+Malfunction
https://www.clublexus.com/forums/es-...th-alerts.html
https://www.clublexus.com/forums/es-...ine-light.html
https://www.clublexus.com/forums/es-...-t-so-hot.html
Old Nov 3, 2023 | 01:02 PM
LS500Fan's Avatar
LS500Fan
Try operating the park brake a couple of times. If the message persists after a few drives also talk to the dealership.
Old Nov 3, 2023 | 01:25 PM
grp52's Avatar
grp52
https://www.clublexus.com/forums/sea...rchid=26304345
I don't think your search link is working as you intended. For me it results in "Sorry - no matches. Please try some different terms."
Old Nov 3, 2023 | 03:24 PM
july1988's Avatar
july1988
I updated with actual links, I was searching this sub-forum for "Parking Brake Malfunction", and apparently every time you search for something, system will give you an ID for the results, but it will expire in no time LOL (instead of using query string, for security reason, some IT/HTML PHP BS )
p/s: this happened to me ~2 years ago, 1 month sitting in dealership (because of waiting for parts from oversea in middle of COVID), they fixed under warranty...
Old Nov 3, 2023 | 03:30 PM
BBQapple's Avatar
BBQapple
To prevent is it suggested to use the PB often, or rarely?
Old Nov 6, 2023 | 12:17 PM
Weaboo99's Avatar
Weaboo99
7th Gear
So when refilling gas last Thursday noticed that the gas cap was in locked in and the check engine light and that message cleared about 120 miles of driving between now and then. Turns out that was the culprit as that cause an evap leak
Old Jun 5, 2024 | 07:52 AM
MrSmoas's Avatar
MrSmoas
2nd gear
Default Was the problem resolved?
I had the same codes appear on yesterday. I took it to my local mechanic and he suggested a new throttle body. Remind you this happened at the gas station right after I filled up. 2021 ES 350 F Sport with 60k miles. What did you have to do? Are there anyone who experienced this? If so, what was the fix?
johnsnia
NX - 1st Gen (2015-2021)
Jul 19, 2023 01:49 PM
NoobExe
Apr 4, 2022 01:16 AM
dangla1603
Feb 2, 2017 05:54 AM
Alphaman19
Jun 23, 2014 11:39 AM
Katoosh
Jun 26, 2013 08:48 PM
