Initial Oil Change
Old Dec 8, 2023 | 07:17 AM
  #46
xmlstarks's Avatar
xmlstarks
Any great 0W16 "full" synthetic oil, even Amazon Full Synthetic. LOL I use Liqui Moly 0W16 Special Tec AA or if you can find it - Liqui Moly Molygen New Generation SAE 0W16.
Oil Filter - Toyota OEM #90915-YZZN1
Washer - Aluminum or copper, compression washer the best.
Old Dec 8, 2023 | 08:13 AM
  #47
LS500Fan's Avatar
LS500Fan
My first oil change was at 10000 miles and second at 20000 miles, it hasn't blown up yet. If you are worried at 1,100 miles what happens if you smell gas in the oil again at 2,200 miles?
The slight fuel smell is not concerning it's normal if you've been doing city driving. Go take it on a 30-45 min drive on the highway and that fuel will be burnt off.
Old Dec 8, 2023 | 08:37 AM
  #48
Lexicon1's Avatar
Lexicon1
Default For oil change....Filter wrench
Originally Posted by scubapr
Hi to all, hope this does not start another flame war over intervals. Not my intention, as I have already made my mind; and don't mind the additional expense $ for my peace of mind.
  • Oil: 0W-16 *Will be using Mobil 1 Advanced Fuel Economy Full Synthetic
  • s!
Amazon Amazon
Old Dec 8, 2023 | 10:22 AM
  #49
scubapr's Avatar
scubapr
Thanks! I've been reading about 2 types of filter for this car.
Do you know if the first installed filter is the same 90915-YZZN1 or the case for changing the cartridge/o-rings inside? Anyway, I'll try to jack up during the weekend to confirm.
Old Dec 8, 2023 | 10:28 AM
  #50
Denzlex's Avatar
Denzlex
Buy your filters at the dealership. You’ll know you’re getting the right one, and won’t be counterfeit.
Old Dec 8, 2023 | 10:35 AM
  #51
scubapr's Avatar
scubapr
Thanks! I do understand that logic and agree somewhat. I just want to dump this "First Break-in Oil" even if there were not gas in there; don't mind the "one-time" extra < $100 expense on my $50k+ car.
After that, I'll just adhere to the manufacturer severe driving condition OCI of 5000 miles or 6 months based on my driving characteristics.
Old Dec 8, 2023 | 10:47 AM
  #52
scubapr's Avatar
scubapr
Thanks! Will definitely do.
Old Dec 9, 2023 | 03:30 PM
  #53
YumpinYiminy's Avatar
YumpinYiminy
Default Good topic
I'm sure you have decided by now but just in case someone else is curious.
If the car was always serviced at the dealership than they are lying to you didn't even bother looking into it. I just bought a new 2024 ES350 11/30/2023. I asked if the break in oil change was included in the 1st year free maintenance. Answer NO! They gave all kind of well bla bla bla. So my guess is it wasn't. However that does not mean it's a good or bad car. The oil and filter may have been changed yet the person driving it the 1st 1000 miles may have beat the carp out of it. Just no telling.
For those wondering if you should change oil and filter between 750 and 1000 miles. The answer is yes. Most mechanics recommend it and it's good insurance for little money vs the cost of a new engine at some point down the road.
Old Dec 10, 2023 | 06:46 AM
  #54
xmlstarks's Avatar
xmlstarks
Exactly, change out the factory oil & filter around 1,000 miles. Watch this video to find out why!
Old Dec 10, 2023 | 06:59 AM
  #55
YumpinYiminy
I like watching the Car Care Nut on you tube. Smart guy.
Old Dec 10, 2023 | 07:24 AM
  #56
Shaboom's Avatar
Shaboom
Smart as a business man, too!
Old Dec 10, 2023 | 07:30 AM
  #57
YumpinYiminy
Ya, don't screw over his customers. Getting harder and harder to find good and honest mechanics.
Old May 27, 2024 | 03:41 PM
  #58
Wilson2000's Avatar
Wilson2000
I just completed my first oil change in my 2024 ES 300h. Here are some of my impressions:
1. Like a poster above, I noticed the smell of gas coming from the draining oil. Yikes! Is this due to dilution caused by direct injection? If so, this is another reason to do 5,000K changes vs 10,000K. Hopefully, the dilution diminishes as the pistons/rings/cylinders "wear-in."
2. I noticed very fine glitter in the drained oil when viewing it in the sunlight (confirmed my instinct to do an initial change at 500 miles)!
3. After watching a YouTube video testing an OEM Toyota filter and pitting it against premium filters, I went with a K&N filter rather than OEM. The Toyota filter had some good results for filtering capacity and low flow restriction, but it was horrible at filtering out the finer particulates (thus the glitter). It is less restrictive, so, had better flow. Filtering fine particulates seems more important.
4. Watched another video on changing the oil in 2024 ES 300h and saw the tech was using a Toyota OEM #90915-YZZF1 filter vs the specified #90915-YZZN1. The F1 appears to be about twice as long as the N1. I'm thinking of switching to the longer filter for the change after the 10K mile/1-year service that Lexus does for free. Of course, I would source the longer filter from K&N or one of the other premium filters that tested well, like Amsoil, Mobil 1, Wix XP, or Fram Ultra Synthetic. I'll likely go with an OEM, N1 filter at 5K miles so Lexus can't cancel my warranty for using the wrong parts! If the 10K tech noticed a F1 in place of a N1 upon removal, would he/she even make note of it in the documentation?
5. I love that the 2024 has the spin-on vs the cartridge. Anyone know when Lexus converted this model to a spin-on type? I figure it was recent because when one searches online for a filter for this gen ES 300h, one finds both types of filters.
Generally, I was pleased with the ease of changing the oil in the 2024 ES 300h. The only thing that caught my eye under the hood was the pink coolant remnants that spotted the engine bay, near the coolant reservoirs. I'm assuming the reservoirs were overfilled at the factory, and it escaped through the overflow ports. In my 2011 ES 350, Lexus used a hose to direct the overflow to down under the engine bay. Why didn't they do the same here?
Old May 28, 2024 | 12:28 AM
  #59
ESh's Avatar
ESh
The gasoline smell is because of the fuel dilution, because of the GDI system.
They used spin on and cartridge filters in paralel but they quit with the cartridge in 2017.
Old May 28, 2024 | 04:33 AM
  #60
scubapr's Avatar
scubapr
I noticed the same on mine; but I suppose dilution is very minimal as my lab results showed no measurable gas on the sample. The ES300h uses D-4S which uses both direct & port injectors which minimizes oil dilution.
I did my first oil change @ 1,300 miles and a second @ 2,694 miles (~1,300 additional miles).. There was definitely a substantial reduction (50%+) in wear-in metals between the 1st and 2nd basically using the same oil miles interval.
