2013 lexus es 300h tpms reset
I recently replaced all the TPMS sensors(OEM)on my 2013 lexus es 300h in a local tire shop. After the replacement there are no warning TPMS lights on the display. However, the tire pressure display shows all dashes on the odometer. I tried to locate the reset button over the brake pedal and around the gas pedal but could not find it. I also tried looking into vehicle settings but no luck. Also, tried long pressing the display button and navigated through all settings but could not locate the tpms reset.
Please help!
Please help!
I just watched a video from TCCN, you will have to take it to a dealership to have them programmed. All the button in the car does is set the threshold of when the light comes on.
I have had 3 2013 Es300h and all have the button there.
What it does it have the computer scan for the tmps sensors again with the ids stored in its memory.
Also even though you replaced with oem sensore the computer has to be programmed with their new ID codes.
Pressing the button has the computer look again for those ids that are stored in the car ecu memory, even if you had the button it would be scanning for the old id numbers.
fabchef
Oct 28, 2022 08:06 PM
