2012 ES-350 Bluetooth Dialing With Siri Hanging Up
Hello:
I've had this problem ever since I bought the car and probably should have asked this question a long time ago.
iPhone connected to BT.
The problem I have is that if I use Siri to try to make a phone call (e.g. press home button, wait for beep and then "Call Mike mobile") the phone will start to dial and then immediately disconnect. So what I end up having to do is then go into my recent phone history and if I choose the last number (in this case Mike's number) and press it the phone will connect and dial successfully. Only seems to happen when I try to use Siri to dial for me.
I've had this problem with the last 3 iPhone models (4,5 and now my 6). Has anyone else had this problem and if so how did you fix it?
Thanks!
Thanks!
