ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Rubber seal squeak from driver's door
Old 12-02-13, 10:38 AM
CopyCat123
CopyCat123's Avatar
Default Rubber seal squeak from driver's door
I have noticed a rubber squeak from my driver's door on my 2010 ES 350. It disappears when the rubber is wet so I am thinking perhaps there is a silicon product that I could apply or another fix for this? Any solutions out there?
Old 12-03-13, 05:46 AM
igzy
igzy's Avatar
Which rubber seal exactly is squeaking? There are a few on the door. It could possibly need door adjustment so to get rid of it rather than lube...
Old 12-03-13, 07:04 AM
chbow
chbow's Avatar
You can try einszett gummi pflege stift, (yes that's spelled correctly!) I don't know if it will solve your problem as Igzy says but people swear by it.
Old 12-26-13, 05:58 PM
CopyCat123
CopyCat123's Avatar
the rubbing noise seems to be coming from overhead the door not the rubber after all? Anyone out there that had similar problems?
Old 12-31-13, 07:27 AM
greenchile
greenchile's Avatar
I used a silicon spray lubricant and wiped it on all the rubber seals and the surfaces they seal against and it got rid of the rubber seal sound on my door. If it is overhead, it might be the seal for the sunroof making similar sounds. You can clean/lube that seal and sealing surfaces the same way except the rear seal will be difficult to reach.
aventur2
07-21-18 05:38 PM
Kennyr44
06-15-17 03:20 PM
lexusGTP
09-17-12 10:00 AM
Eds98LS
03-08-12 07:27 PM
sc4001992
SC- 1st Gen (1992-2000)
11-22-08 10:48 PM
Quick Reply: Rubber seal squeak from driver's door
