Navigation system don’t work
Old Oct 10, 2022 | 09:21 PM
gegesha's Avatar
gegesha
4th Gear
Default Navigation system don’t work
Hello. A few days ago this happened to the screen
Only the rear view camera works.​​​​​​​
I contacted the dealer, but they only told me the cost of repair and did not tell me the reason or what is damaged
If anyone has had a similar case, please tell me how you solved it, or what I should do.​​​​​​​
DEALER WAS ASKING $11000K TO FIX THIS PROBLEM AND OF COURSE I CANNOT PAY THAT MUCH​​​​​​​
This is a 2015 Lexus ES300H. Thanks
Old Oct 11, 2022 | 07:22 AM
bc6152's Avatar
bc6152
Go to a salvage yard and look for a replacement.
Old Oct 11, 2022 | 07:50 AM
gegesha's Avatar
gegesha
4th Gear
you are a genius
Old Oct 11, 2022 | 10:07 AM
mcomer's Avatar
mcomer
Attempt to get the Diagnostic screen to come up:
Engine running, in Park, doors closed, press and hold the
center console "Menu" button. Turn the light switch on the
turn signal stalk from Off - Tail - Off - Tail - Off - Tail - Off.
You should now have the Diagnostic screen with Failure Codes
Note: even when working properly the HDD test takes a couple
of minutes and you can not back out of this test until it completes.
This may give you the answer to which component has failed.
The symptom diagnostic flow chart from Lexus is short and cryptic:
A message is displayed to inform the driver that the program cannot be read, and the system cannot be operated using the remote touch -
Suspected Area: Multi-media module receiver assembly
Next step, remove and replace the Multi-media module receiver assembly
Old Oct 11, 2022 | 10:00 PM
gegesha's Avatar
gegesha
4th Gear
Thanks for the feedback. I tried this but the screen doesn't respond to anything.
Old Oct 11, 2022 | 10:07 PM
gegesha's Avatar
gegesha
4th Gear
I don't think the screen is damaged. If that was the case, the rear view camera would probably not work. Something more systemic is why it cannot read the program
Old Oct 12, 2022 | 08:52 AM
bc6152's Avatar
bc6152
There should be a lot of these used units available from wrecks for a whole lot less than what Lexus wants. $11k is ludicrous. Here's one example:
https://www.ebay.com/itm/27526836897...saAvWGEALw_wcB
GOOD LUCK!
Old Oct 15, 2022 | 08:43 AM
Armo91's Avatar
Armo91
I started having problems with my infotainment system yesterday on my 16 es350. When i start the car the screen goes blank after the Caution screen, then it will try to start again with the Lexus logo and crash at the same Caution screen. Sometimes the screen doesnt even turn on after starting the car but the back up camera works normal. What ive noticed is while its trying to reboot and failing the ac/heater lights are dimmer then usual. The center console lights take on their normal brightness only when the screen turns on and works properly. Idk what is going on out of nowhere
Old Oct 15, 2022 | 12:23 PM
703's Avatar
703
Check if your alternator is outputting the correct voltage.
jaksaadoun
IS C
May 16, 2021 08:32 PM
BAOZHAI
Dec 27, 2018 04:59 AM
dbs600
Apr 13, 2014 06:22 PM
seanw
Jul 11, 2007 05:39 PM
