Battery question
It's a 2007 ES-350.
I went to the car yesterday and immediately noticed the driver door was ajar.
Sure enough the car wouldn't start, the battery was totally dead.
I noticed some corrosion on the negative terminal.
A buddy came over and boostered the battery and the car started.
I let it run around 10 minutes before driving off.
The battery light did not come on.
Drove back that night with no issues.
Drove the car today with multiple stops (engine off/on) with no issues.
Questions:
1. Can a battery be drained totally as was my case, and then come back to life as normal, or will
I soon have problems with it?
2. What would you recommend I do?
So if you see corrosion it’s a good sign to get a new battery. Costco has a good deal on Interstate AGM batteries but you may need to wait till one comes in (I called once a week till it showed up).
Reading of 12V, can't get finer than that.
The name at the top of the battery is:
8002 6L
MF
If that means anything to anyone?
Does that tell you anything? (It doesn't have a red top, it's black).
I have an appt. at a mechanic shop tomorrow.
8002 6L
MF
Well this is what the test yielded today:
Result: Replace Battery
Battery rating: 600 CCA
Voltage: 12.50V
Measured: 273 CCA
Temperature: 68F
Cranking health: Replace Battery
Reserve health: No test
So I made an appointment to replace the battery on Wednesday afternoon.
The report I gave above came from the computer read-out.
First off when I arrived, he said he couldn't find me in the appointment schedule!
Then he said come back in 15-20 minutes to get my car.
45 minutes later it still wasn't ready.
This is what the service guy wrote on the my invoice/receipt,
directed at the repair guy:
"Customer reports battery dies and will not hold a charge."
Both were fabrications!
My battery died once, on Friday.
It held its charge before that time, and since it was boostered on Friday.
