Temperature sensor differences
Hello. I'm sure this has been answered before, but I couldn't find it. I'm getting ready to do extensive cooling system maintenance when I replace the timing belt. Everything is still original at 19 yares old with 84K miles. I know there's 2 senders. Radiator and water outlet. Are these the same part number? When looking up on Rock A, I can only find 1 listed.
Thanks!
Thanks!
Sensor is here look at the ones that say on radiator
https://www.rockauto.com/en/catalog/...an+switch,4312
Unless the original is bad transfer it over to the new radiator, if you are replacing it. The other sensors why do anything unless they are bad?
Thanks for the link. Nomenclature got me. One is a switch the other is a sensor.
That's a fair question. Basically it's a preventative maintenance issue. The vehicle is 20 years old. Everything has a lifespan (even Toyota/Lexus) Considering that I'm replacing all the hoses, T-Stat (getting a temp below operating range check engine code), coolant and radiator (I've never had a plastic tank radiator last much beyond 100K). I just didn't want to do everything and then have one of these go south and have to drain the coolant and replace it before the next coolant change in 5 years. Not worth it for the price of the switch/sensor IMHO. Yes, I may be spending a little more than I may need to at times, but I've adopted this practice from my 35 years as a FAA certified Part 121 commercial airline mechanic. It has served me well over the years and I despise having to do anything more than once.
Thanks again for the help!
The switch in the rad does tend to fail, can't say how good non Lexus parts are here since I avoid jobber parts when ever possible. Plastic capped radiators suck but Toyota used to be able to make them last I have one that is 33 years old @300k miles original rad is still fine no leaks.
Yeah, know what you mean about replacement parts. I try to source OEM whenever I can. I thought that fan switch was prone for failure. So that is the one in the radiator bottom???
A Denso replacement radiator is only $65.00. Pretty sure that's OEM. Put a Denso in my Avalon and it's been great. Do you know how I can tell if I have one with a trailer tow package? RA has two different radiators. I'm assuming the trailer one had a thicker core. (But we all know how "assume" is spelled...LOL!
Thanks! Have a great 4th of July!
BTW; Did some more research on the radiators. Specs quite different. Here they are FWIW:
Non tow
DENSO 2210503 Specifications Core Height 15.6870 in. Core Thickness 0.6250 in. Core Width 29.0000 in. Inlet Diameter 0.9370 in. Outlet Diameter 0.9370 in. Transmission Oil Cooler Included Yes
Tow Package radiator:
DENSO 2210504 Specifications Core Height 15.8120 in. Core Thickness 1.0000 in. Core Width 28.9370 in. Inlet Diameter 1.3750 in. Outlet Diameter 1.3750 in. Transmission Oil Cooler Included Yes
Big difference in the inlet/outlet size
Non tow
HamandTurk
Mar 6, 2015 04:07 PM
gs300ctn94
GS - 1st Gen (1993-1997)
May 6, 2010 05:11 AM
DeuceLV
Nov 24, 2009 09:06 AM
