Driver’s side control arm replacemnt
Has anyone had the driver’s side control arm replaced yet?
I was on a Toyota site and apparently the 2013-2018 Avalon (same as the ES350) requires the engine and transmission removed to replace the lower control arm on the driver’s side. So, I was just wondering if anyone has had this done yet...and if anyone has seen a solution around that?
The issue is the transmission mount on the driver’s side. Not a lot of videos/info out there about it, but I imagine the cradle can be lowered, while removing an engine mount and gaining access to that transmission mount? But has anyone had to do this yet? Dealers are saying the entire engine and transmission must come out...10 hours labor...close to $2,000. I’m coming off a Lexus LS460 and I was thinking that my control arm problems were behind me.😂😂😂
First I have heard this. As a mechanic, it is really hard to imagine having to take out the engine/trans for a front end wear item. Sometimes certain items just have to be studied to see if there is an alternate method to the manufacturers instructions. Now I want to look at it, and will next time I change oil.
Not sure the ES 350 will have any unnecessary wear like the LS. The ES 350 is a lot lighter vehicle and has a better track record of front end wear items.
I have replaced the control arms on my LS460 (twice), and it’s a very simple repair despite what people think of it and despite the amount of labor the dealership bills you for. It’s a two hour job MAX...and that’s for all 6 control arms.
I have replaced control arms on highlanders and Camry’s before - and although they are not fun - I just can’t imagine that tranny mount on the drivers side being unremovable without taking out the engine. So, I’m wondering if anyone has actually had to do it yet.
There are videos on YT for the Camry dealing with this issue: seems there may be an engine mount and/or transmission mount that needs to be disconnected but certainly not to the extent of removing the engine/tranny combo from the car! Just do a search for "Changing control arm on Avalon".
It is not uncommon on cars with subframes, to used an engine support when doing some tasks. I have done same on one of my cars when I replaced subframe bushings. In the diagram in the earlier posts, it mentions "when not using an engine support bridge".
dbogumil
May 22, 2017 07:00 AM
Lafool09
May 2, 2008 03:15 PM
