Weak Compressor? $2000 repair!
Just picked my 2007 ES350 from pep boys, had them diagnose the A/C (was hoping it was just a recharge). They inform me the compressor is "weak" and not circulating the freon, no leaks though. Of course they want $2,000 to replace it, without the labor warranty, $1,800. I see compressors on Rock Auto for $300 but I am not sure which one I would purchase (they quoted $700 for theirs). I searched this forum and there was a thread where a guy measured the voltage and added an amplifier he designed to save replacing it.... that is too much for me. I have no car skills and I don't know how to find someone who could test/do that in Atlanta. I always try to buy my parts because $700 is unacceptable.
Is this the compressor I should order for my mechanic to use? https://www.rockauto.com/en/moreinfo...sn=824&jsn=824
I matched the part number from the dealer website https://parts.nalleylexussmyrna.com/...2480-8719.html
Also, many shops will not work with owner supplied parts or will not warranty their work with owner supplied parts. Especially something as complicated as a compressor.
However since they said it was weak and there were no leaks, I think you should try the $5 magnet fix.
Look at this thread from the RX350 forum as it has the same engine and AC and someone found a $5 fix where they put a magnet on an external sensor on the compressor to make it work.
What happens is the sensor has a voltage sensing issue and will not turn the compressor on. The magnet makes the sensor sense and switch the compressor on.
Most of the info you need starts on page 5 where they show the compressor sensor and where to place the magnet. Post 88 shows a photo of the magnet on the sensor.
https://www.clublexus.com/forums/rx-...-solution.html
What appears to be the correct sensor is on ebay for about $30, This is the listing title
A/C FLOW SENSOR for Denso TSB19C Compressor fits Toyota Lexus 3.5 Liter Engine
