Idler pulley's reverse threaded?
Old Oct 13, 2016 | 10:13 AM
MadPuppy's Avatar
MadPuppy
Default Idler pulley's reverse threaded?
Hello all,
New owner of a used 2007 ES 350 (149,000mi)
I had a squeal from the engine bay I diagnosed as the Serpentine belt.
I replaced the Belt no problem.
While in there I checked the idle bearings, and can see that the idle pulley to the left of the tensioner needs replaced.
2007 ES 350 serpentine belt diagram.
Bad pulley bearing (x)
thing is I couldn't get the bolt off......
After putting it back together and now having just a slight squeal (especially when placing the car in gear) I realized the idle pulley may in fact be reverse threaded?
Can anyone confirm this for me?
It's such a simple replacement I would like to save the $$ by doing myself.
**I also noted the idle bearing on the AC compressor also needs replaced, a bit tougher to access with a cross member in the way and hard to access bolts of the AC compressor (if I wanted to move it out of the way).
I think moving the Alternator out of the way would give me access to the AC compressor bolts on top side.
Probably have my mechanic tackle that one.
Old Oct 13, 2016 | 10:56 AM
nevernu's Avatar
nevernu
this is all i could find. the removal seems normal and the install gives the torque values
File Type: pdf
File Type: pdf
Old Oct 13, 2016 | 11:26 AM
MadPuppy's Avatar
MadPuppy
interesting, no mention of reverse thread....
Gonna have to get some PB blaster penetrating oil on it.
thanks Nevernew
Old Oct 13, 2016 | 12:48 PM
Blue Moose Engineering's Avatar
Former Sponsor
In which direction does the pulley run? Clockwise or counter clockwise? The threads are likely the opposite of that
Old Oct 13, 2016 | 03:05 PM
ESh's Avatar
ESh
Clockwise.
Old Oct 14, 2016 | 08:44 AM
Former Sponsor
Then it looks like both those idler pulleys spin counterclockwise and therefore, I wouldn't be shocked to find that the bolts are reverse thread. I have encountered that on some other cars in the past.
Old Oct 14, 2016 | 09:28 AM
nevernu's Avatar
nevernu
you would think the factory manual would mention that on removal instruction if reverse threads were the case; id ask the dealer if there is some doubt
Old Oct 14, 2016 | 09:43 AM
Former Sponsor
If you tried to get the bolt off in the normal direction and it wouldn't move, why not try to get it off in the other direction? What's the worst that could happen?
Old Oct 14, 2016 | 11:24 AM
jkayca's Avatar
jkayca
Shear off the bolt?
Old Oct 14, 2016 | 12:40 PM
ESh's Avatar
ESh
Wait. Maybe I wa not clear. The alternator rotates in clockwise direction. The ADP spins in counter clockwise.
If you want to replace it you need a strong air gun. There's was no way to release mine without it.
Old Oct 15, 2016 | 05:58 PM
jagtoes's Avatar
jagtoes
Doesn't matter they are normal right hand threads.
greenRX300
RX - 1st Gen (1999-2003)
Jul 3, 2017 09:56 AM
dgb744
Jul 2, 2013 04:13 PM
over40driv
Sep 23, 2011 07:54 PM
drolyat
Aug 5, 2009 03:25 AM
