Trunk opens without key fob present.
Old Dec 3, 2015 | 09:34 PM
NdYAG's Avatar
NdYAG
Originally Posted by jbm79
My 2013 needs the key to be present to open the trunk from the outside, whether the doors are locked or unlocked. Also, Carista does not have the option to change this setting.
Are you sure you do not have this option in Carista?
Unlock trunk when doors are unlocked
*ON* / OFF
I have it on my '14 ES300h.
Old Dec 4, 2015 | 08:05 AM
bc6152's Avatar
bc6152
I'm going to check it on my 2013 with the Carista tool. I'll report back...
Update: I could not change trunk opening on my 2013 to open w/o key present thru Carista.
Old Dec 4, 2015 | 08:54 AM
NdYAG's Avatar
NdYAG
Do you mean you did not see this option or that it did not change the behaviour?
Old Dec 4, 2015 | 09:33 AM
JDR76's Avatar
JDR76
This is all very interesting. If you want it to open while unlocked and without the key in range, I would consult with your dealer on your next service visit, as the owner's manual very clearly states that it should work.
Old Dec 4, 2015 | 09:42 AM
Mike728's Avatar
Mike728
All years?
Old Dec 4, 2015 | 09:55 AM
JDR76's Avatar
JDR76
Originally Posted by Mike728
All years?
I found it in the manuals for 14, 15, and 16. Haven't checked 13 yet.
EDIT: Don't see it in the '13 manual, so I assume Lexus added it in '14.
Old Dec 4, 2015 | 11:50 AM
bc6152's Avatar
bc6152
I tried it thru the Carista app on my 2013 and the choice is not available by the dealer or owner. IOW it can't be enabled on a 2013 Lexus ES 350. Key must be present whether car is locked OR unlocked to open the trunk. This feature must have been changed for 2014.
Old Dec 5, 2015 | 08:53 AM
dchar's Avatar
dchar
I had a 2013 GS350 which also had the annoying problem of needing the key to be present to open the trunk (even when unlocked), and I tried to have the dealer change the setting but they told me it wasn't possible and they've heard so many complaints about it. Also, if the dealer can't change it, then an app definitely can't do it either. Lexus changed it for 2014+ model years; now my 2015 doesn't have this problem. To those with the 2013, you're unfortunately stuck with the problem.
Old Dec 5, 2015 | 03:02 PM
JDR76's Avatar
JDR76
^^^ Indeed, it's pretty crazy. It doesn't make any sense to me, but at least they remedied it for '14 and on. I'm thankful that both my '14 IS and my '13 RX don't have that issue.
Old Dec 6, 2015 | 10:04 AM
Mike728's Avatar
Mike728
Not really that big of a deal for me. It actually adds a layer of security if my cars unlocked in my driveway.
keithS
RC F (2015-present)
Feb 1, 2023 04:58 AM
lovemylexi
Aug 6, 2015 11:17 AM
LexusLov02
IS - 1st Gen (2001-2005)
Jul 2, 2015 11:38 PM
attimus02
Aug 27, 2012 06:58 AM
SerKevin
Jan 29, 2007 10:05 AM
