Engine or Something Knocking?
Old Jun 30, 2015 | 03:38 PM
funcrusher's Avatar
funcrusher
Default Engine or Something Knocking?
Started about 2 weeks ago. Something under the hood on the drivers side is making a slight knocking noise. It only happens when im going slow as hell like leaving a driveway or parking lot. any ideas what it can be? Can it be the high Houston heat and humidity? 110k miles on a 2000 ES.
Old Jun 30, 2015 | 06:59 PM
ES300NZ's Avatar
ES300NZ
it's impossible to help you from that description, but it's most likely to be a suspension part.
Old Jun 30, 2015 | 11:11 PM
funcrusher's Avatar
funcrusher
Thanks. Someone said try filling with Premium gas and see if it stops.
Old Jul 1, 2015 | 12:17 AM
weirdone's Avatar
weirdone
The knocking sound may also be caused by carb build up in your vehicle's combustion changers or by a low octane fuel.
Old Jul 1, 2015 | 03:48 AM
funcrusher's Avatar
funcrusher
Well my manual says to use Regular. Im gonna fill up with Premium next time and see if anything changes
Old Jul 1, 2015 | 05:47 AM
BDSL's Avatar
BDSL
Is the knocking noise proportional to wheel speed or engine speed?
There can so many things that can produce a knocking noise.....suspension, brake, engine, transmission, or something loose.
Old Jul 1, 2015 | 08:42 AM
285exp's Avatar
285exp
If it's happening at low speeds and the sound is coming from one side only, it's very unlikely to be engine knock and therefore premium fuel isn't going to solve anything. Usually, turning in and out of driveways and parking lots involve more steering lock than normal driving, and the knocking from that one side could be the CV joint.
Old Jul 1, 2015 | 09:17 AM
ZeusES300's Avatar
ZeusES300
It could be the valves that needs adjusting. Funny that this is something you should do everything 60,000 or every 48 months as a routine maintenance.
Old Jul 1, 2015 | 05:40 PM
ES300NZ's Avatar
ES300NZ
you'd never hear that in the cabin. It would most likely be a
cv (clickety click)
a wheel weight strucking something,
a worn lower arm bush (they slide around when worn, it causes a knocking),
a bad shock (moving freely at the bottom, in the strut),
a mis fitting brake pad (sliding in the housing),
a wheel not properly done up (thunk thunk),
a CV main nut (forget correct name), improperly tensioned (spline moving back and forth)
a bad engine mount ? weak and allowing a connection/strike somewhere
that's all I got.
Old Jul 1, 2015 | 05:51 PM
funcrusher's Avatar
funcrusher
Well i put premium gas and i think it went away. I have a fe
Old Jul 1, 2015 | 05:52 PM
funcrusher's Avatar
funcrusher
Well i put premium gas and i think it went away. I have a feeling it was a ghetto Shell that caused it... Will report back after a few days of starting car
Old Jul 2, 2015 | 08:33 PM
funcrusher's Avatar
funcrusher
So I filled up with Premium and its not knocking when i drive slow anymore. But i still hear it when i go over a speed bump
Old Jul 3, 2015 | 09:02 AM
mitmaks's Avatar
mitmaks
Is it knocking while you drive or is it knocking with engine on and you're stopped?
Old Jul 3, 2015 | 10:57 AM
funcrusher's Avatar
funcrusher
While driving
Old Jul 3, 2015 | 11:28 AM
mitmaks's Avatar
mitmaks
Sounds like cv joint, but could also be a ball joint and/or tie rod that's loose
cdvyas
Jan 25, 2019 06:29 PM
wdtony
Jun 13, 2017 08:38 PM
Buddy888
NX - 1st Gen (2015-2021)
Jun 15, 2015 05:57 PM
mcqmcg
Aug 8, 2012 08:06 PM
RA080623
Jan 29, 2009 10:39 AM
