Windshield replacement question 2014 ES
Old Mar 26, 2015 | 06:50 PM
captarne's Avatar
captarne
Default Windshield replacement question 2014 ES
New to the forum , but I haven't found any information to my questions concerning a windshield replacement and calibration.
My wife received a 15" crack in her 2014 ES 350, and was informed by Safelite Glass(Allstate) that the windshield needs to be calibrated by Lexus after installation. She then contacted Lexus dealer and was told that they don't do calibration and sent her to another glass installer that they use. Well of course that installer does not except Allstate insurance and we would have to pay for the windshield. Which is fine , the question now is what is this calibration and is it so difficult to install the windshield with all the sensors?
Old Mar 26, 2015 | 07:57 PM
zes's Avatar
zes
What does calibration of the windshield mean, specifically? Only thing I can think of is that the rain sensor has to be calibrated to turn on the wipers at the right time? Can you ask Safelight what they mean?
Old Mar 27, 2015 | 12:24 AM
captarne's Avatar
captarne
That's what I think, but it really doesn't make sense. My wife is going to go to Safelite and have them show her what they mean. Frankly it's a little confusing, after all replacing the windshield isn't rocket science.
Old Mar 27, 2015 | 07:54 AM
grabilsm's Avatar
grabilsm
Most of our windshields have the rain sensor and heating element. I am assuming they are referring to one of those. If that is the case the rain sensor doesn't need to be calibrated, and I don't believe the heating element does either.
Word of caution if your using a 3rd party vender to replace your windshield watch them and make sure they are putting a new seal in place don't let them reuse the old one.
Old Mar 27, 2015 | 07:58 AM
bc6152's Avatar
bc6152
I googled this information and found two explanations: One had to do with the rain sensing wipers, and one had to do with defrosting the windscreen. Both were questions on the CL forum. I couldn't make heads nor tails with the questions or answers and so, for me, I would have to ask an installer or the Lexus dealer SM what is required.
Here is a link to one issue with replacement windscreens regarding reaffixing the rain sensor to the inside glass. It doesn't state anything about calibrations.
http://www.quora.com/Where-is-the-Le...w-does-it-work
Old Mar 27, 2015 | 08:09 AM
grabilsm's Avatar
grabilsm
I think what they mean by "calibration" is physically reattaching the rain sensor which is the same procedure as reattaching your rear view mirror...just using some epoxy.
Old Mar 27, 2015 | 08:24 AM
bc6152's Avatar
bc6152
You could be right; the article stresses the importance of reattaching the sensor correctly, which would be akin to reattaching a rear view mirror. Don't know where "calibrations" enters the picture.
Old Mar 27, 2015 | 09:05 AM
jollick's Avatar
jollick
The reference states this:
The calibration is quite exact and can be disturbed by replacement of the windshield with an "after market" or non-dealer replacement. The adhesive tape used to attach the sensor is very important and if not set correctly will perhaps cause the system to fail.
There is not much that one needs to do to maintain the system, as it is designed to be self checking and assumes the windshield will have the normal amount of accumulation of dirt. However there are cases where the system can false trigger by the correct amount of dust or if the sun hits the sensor just right.
Old Mar 27, 2015 | 09:13 AM
grabilsm's Avatar
grabilsm
As far as the insurance part of this, I would demand a lexus oem windshield at this point. You are entitles to OEM quality or better, it seems that they are trying to retrofit this to an aftermarket windshield.
Old Mar 27, 2015 | 09:18 AM
Arty101's Avatar
Arty101
It seems to me that the windshield installer needs to fit the rain sensors exactly where it needs to be, so there's no calibration done by the owner or dealer.
Old Mar 27, 2015 | 09:21 AM
Joeb427's Avatar
Joeb427
If you're going to go with aftermarket glass,go with Pilkington or PGW glass.
Safelite is said to be Chinese crap in most cases.
OEM is the best but some insurance companies won't go for the $$$.
Old Mar 27, 2015 | 09:26 AM
grabilsm's Avatar
grabilsm
I agree it just needs to be "calibrated" into the correct place.
With that aside I would be concerned with which glass Safelite is using. It seems like they have to retrofit the sensor in place, which makes me wonder what else is different about the glass. Id make sure the new glass matches the factor tint, and the additional acoustic layer they add the the Lexus glass. Also make sure you take a hard look at the glass to see if there is any "waviness" to it.
I am hesitant because I have had 'OEM like" quality glass installed from safelite at one point, i believe it was safelites brand, and it was garbage had it replaced like 3 times before I made my insurance put lexus OEM glass in place.
Old Mar 27, 2015 | 10:31 AM
lesz's Avatar
lesz
There have been a couple of other threads here from people who have had windshields replaced by Safelite on their Lexus vehicles and who have not been happy. They have claimed that the glass is not, in several aspects, of the same quality, and they have also talked about how, after the replacement, things like the rain sensors did not work properly.
Old Mar 27, 2015 | 05:45 PM
captarne's Avatar
captarne
Default Thanks for the info
Thanks for the info, I feel better and my wife feels more reassured, Safelite didn't give her a warm fuzzy feeling. So we're going to the installer Lexus recommends.
csstults
NX - 1st Gen (2015-2021)
Jun 14, 2018 11:38 PM
EJC
Mar 19, 2018 08:48 PM
bearcat85
Dec 21, 2009 11:59 AM
wizhill
Jun 24, 2006 09:22 AM
