P0401
Old Apr 1, 2013 | 05:46 PM
morphh's Avatar
morphh
Default P0401
Does anyone know if the p0401 egr insufficent flow, will pull timing or run in safe mode?
Old Apr 1, 2013 | 06:10 PM
mdbrown's Avatar
mdbrown
Negative to both. It's strictly an emissions thing.
Old Apr 1, 2013 | 06:22 PM
morphh's Avatar
morphh
I deleted egr valve, un hooked the vsv connection and now it says p0401. It's a 1994 es300
Old Apr 1, 2013 | 08:26 PM
mdbrown's Avatar
mdbrown
The EGR valve is for Exhaust Gas Recirculation. All it does is route a small amount of exhaust gases back into the intake chamber to reduce combustion temperature. If it sticks open it can cause driveability issues but what typically happens is they clog up like yours seems to have and so they don't work. Won't cause any issues that way. What makes you think you are in safe mode? That is the only code you have?
Old Apr 2, 2013 | 11:04 AM
morphh's Avatar
morphh
yea that is only code i have, i deleted it because i broke a tooth pick in one of the vaccumm ports cleaning it. i was reading someone else saying that it might retard the timing cause i put a plate over it.
Old Apr 2, 2013 | 12:15 PM
mdbrown's Avatar
mdbrown
Backtrack just a bit. What, exactly, is going on with the car?
Old Apr 2, 2013 | 03:33 PM
morphh's Avatar
morphh
I had p 0401 so I was cleaning egr valve and the vacuum ports located on the throttle body when I broke a tooth pick in one of the ports on throttle body that feed vacumm to the egr , so then I just blocked the egr off. I just didn't know if it would make the car run bad, another question do you the bolt for the transmission the size of it to dump and refill don't know size of the trans bolt.
Old Apr 2, 2013 | 04:07 PM
morphh's Avatar
morphh
trans drain plug size
diamondave
May 25, 2013 08:22 AM
johnblagg
13
Jan 3, 2012 05:28 PM
FAT HEAD
Dec 21, 2009 11:00 AM
fkarriem
Nov 21, 2006 02:27 PM
GSquicksilver
GS - 1st Gen (1993-1997)
Mar 31, 2003 12:48 AM
